Brake pads performance with less dust
01-16-2014, 07:05 PM | #1 |
Rep 37
I have an 08 335i e90 and currently have bmw brake pads. I just purchased new wheels that will be more difficult to clean and am concerned of the amount of brake dust these pads produce. I am looking for a pad to reduce brake dust but not sacrifice performance I would appreciate any suggestions. Thanks
01-16-2014, 07:25 PM | #2 | |
90
Rep 1,677
01-17-2014, 10:40 AM | #4 |
just another bmw douche bag
195
Rep 3,640
well, that is going to be a bit difficult. The akebonos sacrifice quite a bit of performance IMO, and I would never put them on my car again. I am currently using hawk HPS, and the initial bite isn't quite as good the stock pads, but it's much much better than the akebonos. A lot less brake dust than stock, but a little more than the akebonos.
01-18-2014, 11:36 AM | #7 |
Rep 17
I've been using Akebono's on my 08 335i e90 for over two years and am happy with them. They have less initial bite than OEMs, but perform very well and are virtually dust free.
01-19-2014, 11:10 PM | #8 |
Where'd my VTEC go?
481
Rep 6,067
BMW changed the pad compound a few years ago so if you get the newer OEM pads they have practically zero dust. There is less initial bite than the older dusty pads though.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
01-20-2014, 03:01 AM | #9 | |
No 55mph
1622
Rep 8,476
Now that I'm out from under free replacements, I went with the Akebono's & I'm happy with them. I have no problem stopping the car, nor does it feel as if the car won't stop. I would not use pads on any of my cars that were not safe. The Akebono's don't hit as hard initially as OEM's but have a progressive feeling. The OEM pads had good initial bite, but then they would drop off. After using the AK for a couple days I didn't even notice the difference in initial braking anymore. Plus they are almost dust free and rotor friendly - gone are the days of cleaning completely black wheels after every 3 days Cool Carbon pads are supposedly also a good choice...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
01-21-2014, 01:00 PM | #10 |
29
Rep 542
Drives: '11 BMW 335i
I had akebono's on my 325i and experienced almost no brake dust. I plan on getting them for my 335i and get hawks for the rear unless I can find akebonon's for the rear. Does anyone know if they have akebono's for the rear
U.S. Army Veteran/Iraqi Freedom
11' 335i -M-Sport/LeMans Blue Metallic/Sport/Premium/AT - Current 06' 325i -Base/Arctic Metallic/MT - Retired |
01-21-2014, 01:26 PM | #11 |
No 55mph
1622
Rep 8,476
They make them for my 328i - I got mine from TireRack
Either go here: http://www.tirerack.com/, plug in your car info, then go to brakes section and check out the Akebono's available -OR- Go here: http://www.akebonobrakes.com/aftermarket/index.html, click on 'Akebono Web Catalog' on right hand side of screen, plug in your car info, get appropriate pad P/N's I think you car uses EUR918 Front/EUR1170 Rear The 918's for the front have clips on the outboard pads as well as the inboard's. If you don't have cilps on your outboard pads - you'll prolly need 918A pads...
01-22-2014, 02:34 PM | #15 | |
630
Rep 1,649
34116794917 vs. 34116794920 |
01-22-2014, 04:05 PM | #17 |
No 55mph
1622
Rep 8,476
Well, I have an 09' 328iX - I checked on Penske Parts & the Front/Rear calipers on my car have the same part number from 9/07 to 4/12.
However, there are (2) different pad part numbers for both the Front/Rear depending on years used. One P/N for 9/07 to 9/09, and a different pad P/N for 9/09 to 4/12. So that confirms that even though the Front/Rear calipers on my car NEVER changed - there are (2) different pads that were used depending on production date - so either of the pad P/N's would work on my car... Now whether the later pads are the one's that dust less or not, IDK But the dusting you describe with the new less dusting BMW OEM pads is exactly like what I get from the Akebono's. Wheels take a long time to show any dust, & when they do, it's a very light tan color that you can't even tell is there unless you wipe your finger over the wheel.
