Fault Codes 5dbd & 5da7
01-16-2014, 09:21 AM | #1 |
71
Rep 1,027
Posted a few days ago on 1 addicts and for some reason cant reply to my own thread. E90post probably larger audience as well.
Mushy brake pedal and yellow brake warning on dash, with no fluid leaks. Planning to replace pads, rotors, master cylinder but am wondering if anyone knows what these codes mean? Hoping i don't need any really expensive components in addition to those listed above. With car parked, standing on the pedal gave the following: 5DB2 Yaw rate sensor: DRS sends signal AY2=invalid (DRS-Typ MM 3.x). Error will cause a warning light Error is not currently present Test conditions have been completed 5DBD Valve (USV1): General error. Error will cause a warning light Error is currently present Test conditions have been completed 5DA7 Outlet valve (OV) front right: General error. Error will cause a warning light Error is currently present Test conditions have been completed Anyone have or had these? Any help or feedback helpful. Do not want to go to dealer blind (or unnecessarily)
Just like Indiana...I love my whip
04-13-2017, 09:08 AM | #2 |
12
Rep 91
I've got the exact codes being thrown in my car! I also get the DSC and ABS Warning lights popping up on my cluster. Fortunately, the vehicle hasn't thrown the deadly 5df0 - pump unit faulty & 5df1 - pump unit plug faulty as this would require the ABS hydro pump to be replaced($$$).
Any resolution to this? This comes and goes. I think one of the front wheel bearings is going (getting loud at a certain low speed and can be felt slightly through the steering wheel), I've heard this can disrupt the wheel speed sensors. I've recently had a new Non-RFT tyre fitted to replace a tyre puncture (all others are RFT tyres) and a wheel alignment and ever since this job of work these errors have come up. Perhaps this has something to do it... I know these cars can be fussy but Dayum! |
04-13-2017, 10:33 AM | #3 |
4276
Rep 9,206
5DB2 - Wheel-speed sensor: increment gear, rear left
5DBD - Hydraulic unit,changeover valve 1, rear-axle circuit,rear left:leakage or air 5DA7 - DSC: Control unit, valve activation, valve timing So DCS faults and ABS sensor on left rear wheel. Start with the sensor. |
04-19-2017, 08:52 AM | #4 |
480
Rep 1,600
Do you have access to INPA? Once you verify that the brake system is mechanically sound, you can recalibrate the valves, yaw sensor and acceleration sensor and see how you go from there. Dealer software (ISTA/D) will provide better feedback if things dont proceed as expected though.
If worse comes to worse, the control unit and valve block can be sought separately. Swapping control unit will require coding though. Good luck and keep us updated |
09-05-2017, 11:41 PM | #5 |
Roll Tide
591
Rep 2,345
I also have these
5DBD DSC: Brake system, rear-axle circuit, rear left: leakage or air Error will cause a warning light Error is not currently present Test conditions have been completed 5DA7 DSC: Brake system: leakage or air Error will cause a warning light Error is not currently present Test conditions have been completed Super frustrating.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306 |
