Transmission mount - when should it be replaced?
01-14-2014, 03:50 PM | #1 |
33
Rep 571
Hi guys,
Been trying to find out some info on when it's recommended to replace the transmission mount on a 335xi (automatic trans). But I've really just come up short. Is there a recommended mileage where it should be replaced? Or do you not ever really have to? I'm approaching 100k on my car, and I'm replacing the motor mounts this Friday so I was wondering if I should do the trans while I'm at it. Cheers
-335xi---Innotech Exhaust---AR 3" Catless---Pro tuned---HPF FMIC---ER Chargepipe---KW V1---Injen DCI---BMW Performance Front Bumper, Rear Spoiler & Door Sills---Vorsteiner wheels---much more-
01-14-2014, 05:04 PM | #2 |
Chief Executive
303
Rep 2,889
Drives: 2008 335xi 6spd Coupe
is the car bucking at all?
01-14-2014, 05:18 PM | #3 |
33
Rep 571
A little bit. But it has been for a while and Im not sure if its the software of the mounts
01-15-2014, 05:00 AM | #5 |
Rep 95
I'd be surprised if your mounts are worn! I wouldn't think this is an item changed at a specific mileage interval. Maybe a good idea to rule out any other causes?
02-01-2014, 11:21 AM | #6 |
Rep 6
You don't really need to replace the mount unless you notice some sort of banging. Is there any ? Press on the brake and tap the gas a bit and see if there is any sort of movement from the mount.
02-03-2014, 06:17 PM | #7 |
Master of my own domain!!
153
Rep 1,049
Did you ever replace your motor/transmission mounts? Just curious how you go to the driver's side motor mount as it seems to be quite a pain to get to. Passenger was too easy.
