N55 engine cut off while driving
01-11-2014, 03:51 PM | #1 |
7478
Rep 10,120
I was pulling into my gym's parking lot this AM and the engine just cut off. If you push the start button while driving it WILL cut the motor off but I know for a fact I didn't push it. The engine just completely cut off and the steering wheel locked up, I'm just glad the breaks still worked otherwise I would have slid into a car in the lot. Once I put the car in park and hit the start button the motor kicked on with no issues.
The minute I got home I immediately scanned the car for error and found the following codes: 29D0 Misfire Cylinder 4: I take it this means the coil or spark plug at cylinder 4 took a hit. 29E0 Fuel Mixture control: ??? No idea what the hell this is talking about. and 343F (no info listed for the code) It also says under all the codes that "Error is not currently present", to me this makes no sense why is it scanning codes that are not present? And no my car is not tuned.. And the car is under warranty so I did make an appointment with the dealer. |
01-11-2014, 07:33 PM | #2 |
enthusiast
117
Rep 997
Drives: 2011 e92 lci 335xi
Wow I would like to know what the dealer says , sorry I can't really offer much knowledge about this case. Good thing brakes were fine, update us!
01-11-2014, 08:26 PM | #3 |
7478
Rep 10,120
They will probably say, "sorry we cannot replicate the issue but best of luck to you sir at least you know the breaks won't fail as you begin to glide towards a truck, desperately clinging to a steering wheel that won't budge and an engine that pretty much told you to fuck off."
I actually found a thread here with a few people posting about the same issue with their n55 based cars. Last edited by Delta0311; 01-12-2014 at 08:25 AM.. |
BM235iW97.00 |
01-12-2014, 05:21 AM | #4 |
101
Rep 1,597
So you drove up to a parking lot... Maybe a dumb questions but your engine didn't cut off because of to low revs? Happened to me actually, was in 4th instead of 2nd...
BEFORE: 130i N52 (2006-2011)
NOW: 335xi N55 (2011- ) |
01-12-2014, 08:14 AM | #5 |
7478
Rep 10,120
01-12-2014, 09:20 AM | #6 |
101
Rep 1,597
Ok Was a guess...
01-12-2014, 10:16 AM | #7 |
82
Rep 1,615
Drives: '11 E92 335i
change the cyl 4 coil pack. Also, not sure what mileage you are at, or if you have the tools or knowledge to do so, but changing your spark plugs every 10-15K miles on a modded 335 n55 is a wise thing to do. I had a nagging cyl 3 misfire error and a limp mode before so..... it happens. I changed the coil pack and changed my plugs and have been running strong ever since.
coil pack: http://www.ecstuning.com/BMW-E92-335...oil/ES2696048/ plugs: http://www.ecstuning.com/BMW-E92-335...ion/ES2538493/ Torque wrench - 17 ft lb each plug spark plug socket adapter: http://www.ecstuning.com/BMW-E92-335...ion/ES2561145/ hope this helps. It's a pretty easy job with the rear engine cover being the most fiddly but if you are running the 335 oem stock cross brace - it's really rather simple. hope this info helps. good luck.
-madmanhiker jax,fl
01-12-2014, 11:02 AM | #8 | |
7478
Rep 10,120
Mileage: 29k Vehicle is fully stock. BTW are the spark plugs gapped? |
01-12-2014, 11:37 AM | #9 |
82
Rep 1,615
yes, they come ready to go.
-madmanhiker jax,fl
01-12-2014, 02:06 PM | #11 | |
enthusiast
117
Rep 997
01-12-2014, 02:45 PM | #12 | |
7478
Rep 10,120
Out of warranty: sure sir we can look into it just pull out your wallet and get ready to bend over for us. And unlike those assholes at Audi we will use lube. |
RoarinForeign35.50 E92TiAg335i217.00 |
01-12-2014, 02:47 PM | #13 | ||
enthusiast
117
Rep 997
I'm going to the dealer after tomorrow with warranty so I'll bring my own lube just in case |
01-12-2014, 04:15 PM | #14 | |
7478
Rep 10,120
After 50k the fun ends and the butt pounding begins. Thank God we're still good, for now at least. What your friends and family think as you role into a BMW dealer out of warranty. Last edited by Delta0311; 01-12-2014 at 04:26 PM.. |
01-12-2014, 07:42 PM | #16 |
Rep 172
I highly doubt that a faulty spark plug will cause the car to shut off. A bad spark plug or coil will just cause the car to misfire and throw codes. FYI I had my car do the same thing it just randomly turned off when I was driving in slow moving traffic. It did it once a couple months ago and never did it again.
01-12-2014, 07:49 PM | #17 | |
7478
Rep 10,120
01-13-2014, 10:40 PM | #20 |
153
Rep 270
Recall campaign No. 13V-044: Power Supply System. Not sure if that's your cause, my car never cut out, but dealers should know all about this recall. It does say in my recall letter, "...The connection between the positive battery cable and the fuse box can wear over time. If the wear is excessive, then in most cases, this can cause a break in the electrical connection and create a non-starting condition in the vehicle. In certain cases, it can also cause a momentary flickering of the display in the instrument cluster or a momentary (less than 1 second) engine shut down. The electrical system may also be completely interrupted during vehicle operation, and result in engine stalling and a loss of various vehicle systems that could increase the risk of a crash.". Worth a shot. Good luck!
2011 335i M-Sport (SOLD), BMW Performance Powerkit Version 1, BMW Performance Exhaust (SOLD), 35% F1 Pinnacle Tint
01-14-2014, 09:14 PM | #21 | |
Libertarian
132
Rep 1,577
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
11-01-2018, 11:37 AM | #22 |
Rep 17
Sorry to bump an old thread, but I really need some help.
I'm having this same issue. However, there's no codes being reported. It just quietly shuts off when slowing down sometimes. Will lose power steering. If I try to start it up again, it starts up without an issue. It's super dangerous driving around with it. Anyone else experiencing this issue and how did you solve it? My mechanics have checked fuel pump, power supply, and even the gas tank. They can't figure this one out. It's a 2011 335i (N55/E93). Last edited by mmille24; 11-01-2018 at 11:48 AM.. |
