Need help finding bolt for negative battery terminal - 2011 E92
01-09-2014, 03:44 PM | #1 |
Rep 13
I was installing a new amp and when i went to reattach the negative battery cable, I over-torqued the nut and sheared off the head of the bolt. BMW wants $500 for an entirely new cable assembly. Not sure how exactly to describe it, but all I need is the little bolt that has the kind of "V" shaped base that clamps down the negative terminal when you tighten it. I think you guys know what I mean
Anyone know where I can get that specific part? I found somewhere online that there was a VW part # that worked, I ordered it and the base is a slightly different shape, doesn't work. Thanks for any help! |
01-09-2014, 08:19 PM | #4 |
Rep 65
looked at mine but couldn't tell if it attached to cable-
its on the bottom) ,, is the bolt attached to cable clamp? if it is attached just cut and drill a hole for a new bolt |
01-10-2014, 04:00 PM | #6 |
Rep 13
Thanks everyone, it looks exactly like this bolt:
It's not attached to the cable, so no dremel required. If I had the correct bolt, all I need to do is put it in and tighten it down. |
01-10-2014, 08:19 PM | #7 |
17365
Rep 18,762
I looked at realOEM, there is no separate bolt shown for the IBS/Neg cable. I suggest taking the bolt to the dealer and see what they can do for you.
01-12-2014, 12:30 PM | #9 |
103
Rep 2,783
lol
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
03-11-2017, 07:54 AM | #10 |
13
Rep 39
Sorry for old tread. But did not get to many posts under search that this tip fit in.
BMW only sell the whole negativ cable with the T-bolt included VW part nr 6X0915138 works like a charm. Just fitted one to my -06 E90 (For a $ extra you get the appropriate nut and washer also.) |
Daaaaaaaan88.00 |
02-01-2023, 10:25 AM | #11 | |
Rep 1
