2010 2011 BMW 5 Series Forum F10 Exhaust valve Open: how to |
01-05-2014, 04:18 PM | #1 |
446
Rep 1,300
Does anyone know the proper way of zip tying the mechanism that keeps the valve open? Is there a how to? What is recommended? Zip ties? Or wire?
I am looking for an increase I'n noise without upgrading exhaust. Thanks. |
01-05-2014, 04:24 PM | #2 |
64
Rep 411
Check it out, halfway down the thread. I managed to do it and I'm not handy at all. Noticed a slight increase, but not as much as the 650 on the clip.
http://f10.5post.com/forums/showthre...&highlight=zip |
01-06-2014, 01:30 AM | #4 |
40
Rep 213
AR,
i am planing to do this... http://f10.5post.com/forums/showthread.php?t=630331 this will take care of the flaps.. |
01-06-2014, 10:33 AM | #5 |
446
Rep 1,300
Great!! Maybe we can do it together!.. I will be honest I Really like the trapezoid exhaust. I think I will do that but retain the original look. i just need a little more noise.
01-11-2014, 12:38 PM | #6 |
446
Rep 1,300
I just did this mod and it took 5 minutes .
I used 10 inch zip ties. It was easy considering the maneuverability of the long ties. The slight increase in sound (10%~15%) . Honestly It is not really noticeable unless it's a cold start. Verdict: this car needs mufflers/ exhuast's. |
04-30-2014, 06:48 PM | #7 |
V.I.P.
36
Rep 242
Drives: F10 535i 2011, F10 550i 2015
I cannot figure out where those vacuum springs are on a 2011 535i.
Instead, I found a connector (looks similar to the E92 golf tee mod connector) on the left side just between the diffuser and muffler tucked in. I unplugged it, did notice a slight increase in noise, Although it threw a TPMS Error I am unsure if that plug was for the vacuum line for exhaust or the TMPS. ANY feedback if that connector is the right one, how I can find this setup for a 2011 535?
F10 550i Imperial Blue/Ivory
BM3 Stage 1 - xHP Stage 1 F10 535i Alpine White/Oyster BMC - Vorsteiner Exhaust - ER Chargepipe - AR Catless DP - MHD Stage 2 - FMIC |
05-03-2014, 07:25 AM | #8 | |
Rep 65
Just did it on my 550 and noticed a slight increase in sound, but definitely need a a new exhaust/muffler eventually lol. |
09-21-2016, 08:05 AM | #9 |
17
Rep 92
Drives: 2007 BMW 335xi
Do you know for sure the F10 535 doesn't come with the exhaust valve? Seems strange since I've been reading the 528 has it and so does the 550. Doesn't make sense that the 535 wouldn't. Can anyone with a 535 confirm this?
09-21-2016, 03:48 PM | #10 | |
932
Rep 4,323
Drives: M340
My E92 335 had valves and they were deactivated by unplugging the connector in the trunk. This does not appear to be the case for 535s.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
danfratamico16.50 |
09-21-2016, 03:50 PM | #11 |
17
Rep 92
I actually don't have a 535, which is why I was asking. I know you can check, I have it on my E90 335. I'm curious to know because I like it and will be sad if it's not on the 535.
09-23-2016, 09:53 AM | #12 | |
932
Rep 4,323
Drives: M340
The car doesn't sound anything like the 335 though. It is much much more quieter. Hope this helps.
09-25-2016, 10:15 PM | #14 |
932
Rep 4,323
Drives: M340
May be for a 550, there are no valves on the 535 as OP was asking.
