01-04-2014, 04:52 PM | #1 |
3531
Rep 11,292
Windscreen and rear screen misted up when stood for a while
I've noticed this a couple of times now with my car that when I've driven the car somewhere, then left it for an hour or so, when I return the windscreen is misted up and rear screen too.
I leave the climate/air con permanently on so when I start the car it de-misted in about 3-4 minutes, but I dont see any other cars parked up with this same misting. Anyone else noticed this when their car has been parked up for a while?
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
01-04-2014, 05:16 PM | #2 |
74
Rep 378
Drives: M135i, becoming an X3!
I've had it a couple of times recently as soon as I get back in. I checked, and there's no leaks. Put it down to the cold, and also how the mats will probably be damp with getting in and out :-)
01-04-2014, 05:25 PM | #3 |
512
Rep 1,404
Couple of things to check, are you leaving the re-circulation on as well as the A/C? (no fresh air coming in), or a leak somewhere? Are the carpets damp? Also check you haven't got leaves or debris blocking the filters under the windscreen area (external), mine are getting blocked this time of year and I'm pulling bits of leaves out weekly at the moment (this could again prevent fresh air coming in)
Current - F80 M3 CP SS/SO | M Performance Extras
Prev - F30 330D M Sport | White | M Performance Kit | Various Extras Prev - E92 330D M Sport | Black | Highline Older - E46 330i | Silver | AC Schnitzer, E36 328i Coupe | White |
01-04-2014, 06:49 PM | #4 |
3531
Rep 11,292
Thanks chaps.
I always leave the re-circulation button in the off position (ie no lights on). I'll check the carpets next time this happens and will check the leaves under the bonnet. I've also noticed a bit of condensation in the headlamps too. I think it could well be a combination of temperature\weather and hopefully it will go away. Just interested if anyone else has had these issues really.....
01-05-2014, 02:14 AM | #5 | |
61
Rep 949
No lights will let air in regardless. |
01-05-2014, 02:28 AM | #6 | |
26
Rep 153
The cause is damp inside your car which is not good. My wife often leaves a damp umbrella in the footwell so check for anything like this especially wet mats/carpets. If you can't find the source it's likely to be in the ventilation system so get a dealer to investigate. |
01-05-2014, 02:39 AM | #7 |
905
Rep 2,651
Drives: M4 Comp Pack
I echo the above IMO this should not be happening in a new car especially to the headlights.
I would get the dealer to check that out. |
01-05-2014, 02:59 AM | #8 | |
6659
Rep 15,858
Re the comments on the auto recirculation, using auto-recirculation won't cause misting. I've used auto-recirc' continuously in my last 3 BMWs without any issue, and I have more damp and humidity up here than most will ever have to cope with. We have anti fogging sensors and the system will detect the need for fresh air anyway, so won't lock into total recirculation when it is working correctly. It only closes to the outside when necessary, even then it is restricted by a strategy which cycles fresh air into the car. HighlandPete |
01-05-2014, 03:09 AM | #9 | |
6659
Rep 15,858
Both my E91 and current F11 show misting in the lights when we have severe weather. Dries out after a short while, (usually within an hour from stopping). Never viewed this as an issue, but more normal behaviour when driving in heavy rain, or it is damp for prolonged periods. If the lights stay damp and misted all the time, then there is clearly a problem. HighlandPete |
01-05-2014, 04:55 AM | #10 |
3531
Rep 11,292
The car had been stood overnight and I've just been out and checked and ALL windows are completely clear of misting. The headlights are also clear too. The weather has been cold and raining/damp around our way today.
So it appears the misting happens under these circumstances:
The couple of occasions this has happened have been in the evening, when its dark (and obviously colder than in the day). The car is only over a month old with 1200 miles. Also, I'm sure I had this happen a couple of times on one of my E90s and certainly my last E90 had misting in the headlamps, again when the car was not that old. Maybe its a case of (in the dealers words...) "...they all do that sir....", or I've just been damn unlucky with a couple of cars!!! Thanks all for your comments and suggestions!!
01-05-2014, 05:12 AM | #11 | |
Supreme Being
1804
Rep 5,425
With shorter journeys and the inevitable moisture from clothes, shoes, coats in this weather I'm not entirely surprised. Just check nobody left a dead body in the boot.
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
01-05-2014, 05:23 AM | #12 | |
3531
Rep 11,292
My drive to work is only about 10 mins and on the whole, dont drive much above 20 mins in it max. (Waits to get slated for buying a diesel with DPF ) Oh, and last time I checked there was nothing dead in the boot.
01-05-2014, 05:25 AM | #13 |
74
Rep 378
I think that's what it is. Mine was doing it over the hols when I was at my Dad's house. Much shorter journeys. Back to normal at home, and no sign of it!
01-05-2014, 05:26 AM | #14 | |
Supreme Being
1804
Rep 5,425
My wife had similar issues with her E88 Convertible - having travelled just over 10,000 miles in 2 years
01-05-2014, 05:33 AM | #15 |
3531
Rep 11,292
My missus has done about 1200 miles in her Fiesta since it was brand new 18 months ago....... and she never complains of misting in her car....(obviously short journeys too)
But there again.... she never uses it..
01-05-2014, 06:34 AM | #16 |
Rep 33
Speculating here, but air at 20°C (typical warmed-up interior temperature) can hold about twice the moisture (water vapour) of air at 10°C [and even more so of air at 5°C etc]. So as the interior cools down, you'll get condensation on a 10°C [/ cooler] surface if the initial level of water vapour in the air (when you turned of the air con with the car) was above 50% [/ some lesser percentage] of the saturation level. I don't know what the air con system does by way of scrubbing water vapour from the cabin's air, but it clearly doesn't eliminate it all (or we'd have very dry mouths). Maybe it takes a while to stabilise the water vapour content?
I'm guessing too that the likely source of this water vapour isn't damp mats etc - it's probably you, through respiration (think breathing out on cold glass). |
01-05-2014, 09:00 AM | #17 | |
6659
Rep 15,858
I sense most of the country is currently seeing weather which I'm typically used to dealing with up here. I know exactly what you are talking about, see it a lot up here in Lochaber Highland Region, as we are used to high humidity and wet getting into cars just through normal use. Get a bit of snow into a car and when the weather warms you can imagine the amount of cars which have misting because of a bit of damp in the carpet mats, misting can go crazy. Add the fact that the typical AC function cuts out at sub 3/4C and we lose the dehumidifying function, this also aggravates the problem. I've taken the carpet mats indoors in the past, to dry them out if we have a period of heavy rain or snow and sense it is about to get out of control. I try and air my car on a good and windy day, just to keep the cabin humidity levels low. Currently have no issues of misting at all, but does need planning and thinking about to keep it so. Just ensure you have no obvious leaks into the car, like leaking inner door membranes, first evidence is moisture or misting on the door sill plates, typically tracks over the door seals and into the carpets. Look for any other evidence of wet getting in, including the boot. BTW, I think you know the score on the diesel and short trips. Won't add a word. HighlandPete |
01-05-2014, 09:30 AM | #18 | ||
3531
Rep 11,292
