Akebono brake question
01-02-2014, 10:54 PM | #1 |
51
Rep 605
Sensor just alerted me I need new pads, And Akebono is on sale place for brakes 55% off, I was just wondering if anyone that has ordered them. Do they come with the sensors? If not I was going to order the cheap Uro brand from ECS tuning...? what could go wrong..LOL Thanks guys!
http://www.ecstuning.com/BMW-E90-330....0L/ES2534770/ http://www.placeforbrakes.com/produc...&car_year=2006 |
01-03-2014, 09:46 AM | #3 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
Just installed these pads, they don't come with sensors. Be careful when installing the sensors because they can break easy. I have a broken one zip tied to my control arm.....
01-03-2014, 09:39 PM | #4 |
51
Rep 605
most definitely , I have thought about just clipping off the sensor like others have, it is easy to visually inspect the brakes anyway
01-04-2014, 07:48 AM | #5 |
Rep 17
I installed Akebono pads 2 years ago. They are fantastic! Low to no dust, and stop the car as well as OEMs. Not as much initial bite, but that is not an issue for me.
01-04-2014, 10:21 AM | #6 |
Gateropode
329
Rep 2,848
I have them for over a year, very happy, no reservation except that they take unusually long to set. After 1 k miles, much better feel tha oem. And no dust.
Go for the cheap sensor. It is just a fancy shaped resistor. |
01-04-2014, 03:12 PM | #7 |
No 55mph
1622
Rep 8,476
Been using Akebono Ceramic pads for a while now - almost no dusting, don't really notice any difference in braking (even though people say less initial bite).
The braking with these is more linear than OEM - OEM pads hit harder initially, then drop off - Akebono have same feeling thru out braking. > Be careful when you order the Akebono's - most vendors list (2) styles of Front pads - (1) that have clips on the outboard pads, & (1) that do not have the clips - my 09' 328iX does not have clips on outboard Front pads. Every vendor wanted to sell me the pads with clips, as that is what their part finder was telling them - I finally had to get email proof from Akebono that the pads without clips were proper for my car. I got my Akebono's on sale from TireRack. So buy the appropriate front pads for your car... > For sensors - I go with PEX from FCPEuro - they are around $15 for Rear & $17 for Front BTW - neither of your links work
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
01-04-2014, 11:25 PM | #8 | |
Rep 9
I was put on hold and made it to Akebono's engineering department where they dicsovered a flaw in the part number data they have been pushing out to all suppliers in the country! Bottom line... There is only 1 set of correct Akebono pads for my 09 328xi which are the same as the non-xdrive. They had a different part number set up for xdrive and they are just wrong. They said they would fix the system ... not sure if they did but for now on I know to just get the Akebono non-xDrive pads and I'll be good. All that being said, the brakes are awesome and practically dustless. |
01-05-2014, 12:05 AM | #9 | ||
51
Rep 605
01-05-2014, 12:18 AM | #10 |
Gateropode
329
Rep 2,848
I did get new rotors at 70k. I think they were originals. You have to measure thickness to see if they are worn or not. Even if they still look great, they could be too thin (safety hazard). If they have a substantial lip on the outside rim, they are probably too old.
01-05-2014, 06:26 AM | #11 | ||
No 55mph
1622
Rep 8,476
EUR918A (Front - no clips) & EUR1267 (Rear) Quote:
When my BMW was under maintenance agreement they replaced both the rotors/pads 1X for free. The rotors all had a hella lip on outside edge @ replacement time. Now that it is on my dime - I use the ECSTuning Geomet crossdrilled/slotted rotors and Akebono pads...
