01-02-2014, 09:41 AM | #1 |
148
Rep 706
New Windscreen
So the car lasted only 9 months, and now needs a new windscreen because of a crack that's appeared after a stone chip
Who should I get to replace it? I'm guessing BMW just use an external company so there's no point going to them directly? Also was thinking of asking when the replace it to put one in with a shade band across the top ... what do you think the chances are? |
01-02-2014, 09:44 AM | #2 |
154
Rep 1,224
If you go to BMW direct it would cost you around £500, they would use original windscreens... Alternatively call auto-glass and they can replace it under your insurance policy.. They will ask you if your car has the green shade, just say yes (even if you don't have ) when the engineer comes to replace, they will not say anything, just make sure you offer him a drink and tip him off £10-20..
01-02-2014, 09:53 AM | #3 |
1854
Rep 3,983
I managed to crack mine at 3 weeks old! Autoglass can happily replace and it'll be a genuine BMW one. You'll be asked if you have HUD and lane changing (what they actually need to know is if it has the camera so if you have active headlights, the answer's yes).
Did a top job on mine - had to pay 50 quid excess. If you look through search, you'll find my post on it back in Oct.
San Marino Blue M3 Competition Package with Carbon tat, ACS RS suspension, uprated brakes, 'modded' exhaust and a weeny bit more power courtesy of JF Automotive; M235i Convertible with ACS Sports Suspension; Disco 5 HSE Lux
01-02-2014, 09:57 AM | #4 | |
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
01-02-2014, 10:43 AM | #6 |
512
Rep 1,404
I think there is, military HUDs rely on something called a combiner which uses phosphor to enhance and reflect the image back (to the pilot etc..) whilst allowing other light to pass through. I'm sure I saw somewhere that there is a layer of phosphor in the windscreen itself, either way you probably need to mention that the car has a HUD when ordering new windscreens.
Current - F80 M3 CP SS/SO | M Performance Extras
Prev - F30 330D M Sport | White | M Performance Kit | Various Extras Prev - E92 330D M Sport | Black | Highline Older - E46 330i | Silver | AC Schnitzer, E36 328i Coupe | White |
01-02-2014, 01:09 PM | #7 |
Specialist
21
Rep 158
if the glass is ordered direct from BMW, it will be like-for-like (if there is an option code for top tint for that car/windscreen spec, it will show).
Main dealer = genuine, BMW branded glass, every time. Autoglass = whatever they have in stock (and they'll try to convince you the glass is as good as the BMW branded ones, blah, blah, blah). If it doesn't have the OEM emblem on it, it's not an "unstamped" one. Even the glass manufacturers are cagey in how they state the differences between the two: http://www.glasstecpaul.com/windscre...y-really-mean/ In terms of the basic fitting of a screen, a few pointers here on an F10; note the smaller detail such as the foam at the bottom of the screen: http://www.glasstecpaul.com/bmw-5-f10f11-windscreen/ You might want to consider another massively neglected part of windscreen fitting: ridding the substrate of contaminants such as silicon, a huge contributor to bond failure: http://www.glasstecpaul.com/what-isn...d-windscreens/ HTH, and good luck. |
01-02-2014, 01:38 PM | #8 |
8567
Rep 19,982
I've thought a couple of times that the replacement screen wasn't quite as good as the OEM screen, mainly some distortion along a narrow strip near the base. However, given I've had 5 replaced screens in the last 6 years, I'm loathe to pay extra for something which I am now coming to see almost as a consumable! Unlike something like a tyre, I'm not sure I appreciate the difference to spend £400 (or whatever someone quoted) on a BMW one, over paying the £75 or £100 excess for an Autoglass one.
01-02-2014, 04:29 PM | #9 | ||
1854
Rep 3,983
01-03-2014, 03:57 AM | #10 | |
412
Rep 1,157
I don't think you can have the HUD and shade band from factory so you will probably not be able to get them both on your new windscreen. You never know though
Current: recovering slowly
Previous: F31 340i Ruby Red IIM5 Singapore Grey, F30 335d Moonstone, F30 320d Tanzanite Blue |
01-03-2014, 04:19 AM | #11 |
3489
Rep 9,709
Mine has cracked too. Stone hit about 2 inches in from the A pillar......went straight into a 4 inch crack.
As long as I get Pilkington I don't mind it not being BMW branded. |
01-19-2014, 08:16 AM | #12 |
19
Rep 186
Windscreen worries - Will vis pack function mess up ?
Hi chaps,
needed some advice… got a chip in the windscreen and had auto glass out today. They are saying a new windscreen is required . Worried … I have vis pack and presume the camera (not to mention auto lights) on the windscreen will only send correct information to the relevant control units if the windscreen is correct for the individually built car. The guy from auto glass seemed only concerned about lane change and HUD options. I do not want my vis pack to be messed up obviously ! Can anyone advise me what to do now and how to have proved by auto glass (if that's what people think is best) that the replacement they are proposing is OEM for my VIN (if that's what it takes to make sure ). Thanks guys |
01-19-2014, 08:24 AM | #13 | |
3489
Rep 9,709
01-19-2014, 09:41 AM | #14 |
19
Rep 186
I think that it might be a real pain in the a*** as you would then have to try and prove the system was working correctly before the windshield was changed.
Anyway, I sent the following email to auto glass which they have forwarded to their fitting branch "Dear Sir, With regard to the appointment today, the technician was of the view that a new windscreen is required. Before proceeding please could you confirm that BMW original parts would be used as the options on my car specify that the windscreen need conform to the function of : 1. High Beam assistant 2, Automatic air conditioning 3. Rain sensor 4. Interior mirror with automatic dip The windscreen part numbers satisfying these conditions are BMW part no 51 31 7 258 063 51 31 7 258 069 Many thanks for your help" |
01-20-2014, 09:22 AM | #17 |
19
Rep 186
The guy said something about multi-damage
01-20-2014, 09:33 AM | #18 |
2812
Rep 4,935
Drives: 340i MPPSK
Autoglass completely screwed up my rain sensing wipers when replacing the screen on my E87, so bear that in mind. Solution is to get the dealer to re-calibrate them.
Life is a state of mind |
01-20-2014, 09:55 AM | #20 |
19
Rep 186
The communication skills of the tech at Sheffiled auto glass I spoke to today , is making me even more nervous of handing over the baby . And reading glass mans posts on the procedure has put me right off trusting those people
01-20-2014, 09:56 AM | #21 |
Specialist
21
Rep 158
This does not surprise me, and I have seen/heard all the excuses such as the damage being too close to the edge, or within 120mm of another chip etc. I have a very strong opinion about their approach to chip repairs, and some of it is supported by fact.
From what I can see, the damage is repairable and if it can be repaired to a good standard (both technically, as well as acceptable to you) why replace the screen? (that question is aimed at them BTW!). As a consumer, I would rather keep my factory fitted screen in the car for as long as possible (legally, as well as for fiscal reasons) and there is also the idea that you will have a claim worth several hundred pounds on your claim history (not to be confused with NCD). My advice would be to argue that the damage is repairable, and if I was making an assessment on behalf of any insurer, I would be recommending a repair based on the fact that the damage is repairable. Happy to take a call on this. |
01-23-2014, 07:50 AM | #22 |
19
Rep 186
benefits of expert advice
Thanks to you Glassman
- Work of autobodywindscreens in Leeds . (Autoglass would have had me watch them destroy my factory windscreen and put in a replacement that they couldn't even confirm the BMW part number of) |
