Couple Tire Questions
10-31-2007, 06:45 PM | #1 |
ASR Turbos+LSD+Meth= :D
73
Rep 1,517
Drives: E92 335i
hey guys wondering a few things...
if you have an lsd (on a rwd e9x)... would that be better for snow and/or deep snow? or would having only one tire spinning create less of a chance of spin out? because i could also see see it as if you're stopped and on a hill and you need traction to get up it, to have both wheels spinning would be better, no?... second question is does the tread-wear rating (if the "traction" rating of the tire stays the constant AA) change traction results if the tread-wear is: 180 versus 400 for instance? thanks again,... on a side note: i chose Yok ADVAN S.4. 's for my winter set-up here in NY.... because i will be driving back to miami and dont want poor winter tires for when i tear it up down there + dont want to change rims. waddia guys think of the choice, here ill link you for all you lazy people http://www.tirerack.com/tires/tires....nSpeedRating=Z
2007 335i Coupe Mods: Check the Garage |
10-31-2007, 07:29 PM | #2 | ||
197
Rep 2,816
2. Try not to be misled by the treadwear ratings. Each manufacturer supplies their own number based on raw testing data. So this number is not useful for cross tire shopping. For example, a 600 rated Michelin tire will not necessarily outlast a 400 rated Pirelli tire. Or visa-versa. The traction and treadwear numbers are obtained using two different methodologies. Do not assume there is a correlation between the two numbers. However...it seems like common sense that a softer/faster wearing compound (which likely would have a low treadwear rating) would also likely have a higher traction rating. But that may not always be the case. To quote from TireRack: Quote:
10-31-2007, 08:10 PM | #3 |
73
Rep 1,517
Drives: E92 335i
thank you for the perfect responce! maybe i should have done more fishing in tire rack before i posted! look forward to your future posts, you seem very informative and helpful, and speedy to respond!
10-31-2007, 08:15 PM | #4 | |
197
Rep 2,816
You have reminded me once again that I need to get a life outside of this forum. |
11-03-2007, 07:12 PM | #5 | |
Rep 266
