F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > WeissLicht Spektrum LED turn signals
Studio RSR
      12-27-2013, 05:57 PM   #1
BMW Lawman
Supreme Commander of Allied Forces
BMW Lawman's Avatar
24
Drives: 2012 335i Sport
Just installed my new Spektrum LED turn signal bulbs from WeissLicht/Bimmian. Pretty cool. Thank you Santa.
If the YouTube doesn't embed correctly, here is the link.
[u2b]http://youtu.be/f78-QxvC-80[/u2b]
New Spektrum bulb on the left, OEM incandescent on the right.
      12-27-2013, 06:13 PM   #2
Chandy168
Australia
17
Drives: F30 328i MG // VW Amarok
Nice tweak! How do you personally find them? These bulbs are plug and play right? And also, are you experiencing any flickering?
      12-27-2013, 07:48 PM   #3
BMW Lawman
BMW Lawman's Avatar
24
Good color and appearance. Very simple install, pull the old bulb out and plug the new bulb in. No flickering while they are on, not sure about when they are off, like at start up when the system checks for burnt bulbs. My E90 LED upgrades would flicker(when the lights weren't turned on) like at start up and randomly when the system was checking for burnt bulbs. I'll look for that with these and report back.
I'll post more photos tomorrow, I only had time to put one in before I had to head out the door to work.
      12-28-2013, 05:49 AM   #4
Chandy168
Australia
17
Definitely a good appearance, takes away the amber bulbs for sure. Waiting for your report before I buy these. Seems like a great mod. Can I ask where you bought them? and for how much?
      12-28-2013, 07:13 AM   #5
BMW Lawman
BMW Lawman's Avatar
24
Go to Bimmian.com and they are a featured product on their home page(I'm thinking I deserve some sort of endorsement consideration from my friends at Bimmian They are sold at the moment, for $54 a set, which includes 2 bulbs. I bought two sets, one for my front turn signals and a second set for my rear turn signals. Both sets I bought are amber(more on how the rear set looks tomorrow, but I was pretty surprised
As far as the "flickering" that occurs from the on-board system checking for burnt bulbs.....yes, it happens. You get multiple flashes at start up and then random flashes every minute or two thereafter. These bulbs are bright, so it is noticeable, at least it is in my not so greatly lit garage after dark. I will test it out tomorrow, outside in the daylight, and see how noticeable the micro flashes are. It's just a single micro flash every minute or two, but like I said, the bulbs are bright, so it would probably be even more noticeable if you were to use the white bulbs, which they are advertising as 8X brighter than OEM. They say the ambers are 3X brighter than OEM. I don't have a set of whites to test out, but I'm guessing if you were to use the white bulbs for the rear turn signals, you would be sporting a pretty bright pink color instead of red, but again, that would depend on the color of your rear lenses(all red here in the US), but more on that tomorrow.
      12-28-2013, 09:18 AM   #6
Presario
Presario's Avatar
413
Drives: 2018 X3 M40i, 2016 435 GC
You can code the flicker off (disable the system bulb check).
Check out the codes here courtesy of forum member benoa.
http://www.f30post.com/forums/attach...8&d=1386142231
      12-29-2013, 04:50 PM   #7
BTT 335i
BTT 335i's Avatar
51
Drives: X5 F15 M Sport- F30 M Sport
The rears is the same reference to the fronts?
      12-29-2013, 11:55 PM   #8
BMW Lawman
BMW Lawman's Avatar
24
Not sure I understand the question.
      12-30-2013, 12:15 AM   #9
Chandy168
Australia
17
The main reason for these is to delete the amber inside the light housing of my f30. However, I'm unsure which bulb type I would have to get. On the Bimmian website, there are so many options:
Name:  Screen Shot 2013-12-30 at 5.11.13 pm.png
Im also assuming that the white bulbs are only white illumination (i.e. when turn signal activated illuminate white) whereas amber is that it only illuminates amber. Are the housing for both the options the same with just different illumination?
Also, how are the rear turn signals going for you?
Sorry if it all sounds confusing, but I'm very confused at the moment
      12-30-2013, 01:02 AM   #10
BMW Lawman
BMW Lawman's Avatar
24
Crack open your owners manual to make sure you order the correct bulb type for your car. I can't say for sure that your Australian spec car uses the same bulbs as my US spec car. My front and rear turn signals are two different bulb specs.
The bulbs are single color, either amber or white. Housings are the same, but there might be a slight color difference in the pin-head sized LED chips that they use for the two different colors, but they are so small that they are almost invisible.
The rears turned out great. Even though they are shining through a red lens, the light that comes through is completely amber and very bright. It's kinda surprising, since I tried an amber OEM bulb in the other rear turn signal, but the light that came through was still red. Like I warned before, I would be cautious about buying a white replacement bulb for a rear lens housing with a red or amber lens color, as the light that comes through may be bright pink(US lens) or a really bright washed out amber color(Aus lens). I would buy amber for the rears if you're thinking of upgrading those as well.
I'll post some pics of how mine turned out, but I found it's difficult to accurately photo lights, especially LEDs.
      12-30-2013, 02:21 AM   #11
Chandy168
Australia
17
Right, I think I get it.. so whether they are amber or white bulbs, they look like:
Name:  Screen Shot 2013-12-30 at 7.18.38 pm.png
or
Name:  Screen Shot 2013-12-30 at 7.19.31 pm.png
It's just the colour of the turn signal that changes (amber light or white light) correct?
wow.. i think i just confused myself a whole lot...
Thanks for being so patient and the input! I'm a newbie to the car modding scene..
      12-30-2013, 09:11 AM   #12
v1k1ng01
v1k1ng01's Avatar
16
Drives: 2013 335i M-sport
PN: PY21W for the Front Signal.
PN: P21W for the Rear Signal, Brake Light, Reverse Light.
      12-30-2013, 09:24 AM   #13
v1k1ng01
v1k1ng01's Avatar
16
Bright, Pritty Rose Pink in fact... I tested a pair of 30 SMD white LED's in my brakes and rear signal for a day, and ended up with gay love notes left on my windshield.
I WILL add though that Amber LED's will shine amber through the red housing.
      12-30-2013, 09:48 AM   #14
BTT 335i
BTT 335i's Avatar
51
Thank you
      12-31-2013, 04:29 AM   #15
BMW Lawman
BMW Lawman's Avatar
24
Yes, the bulbs will look the same, regardless of color of light they emit. Those little yellow dots on the side of the bulbs will be more amber in color on the amber bulbs, and yellow(like in the pic) for white bulbs.
After running these for a couple days, I am very happy with them. These bulbs are nothing like the first generation LED replacement bulbs of a few years back. Highly recommend them, front and rear.
Maybe WeissLicht can come up with one suitable for the brake lights, I would buy it!
      01-02-2014, 05:45 AM   #16
v1k1ng01
v1k1ng01's Avatar
16
Thumbs up
I wish more manufactures like WeissLicht made quality Red CREE LED's.
      02-01-2014, 12:06 PM   #17
Damn Dirty Ape
33
Drives: 2015 Infiniti Q50S
Even the newest WeissLicht led turn signals still flicker?
      02-02-2014, 02:15 AM   #18
v1k1ng01
v1k1ng01's Avatar
16
The flicker is not caused by the LED, the flicker is caused by an internal diagnostic in the ECM. The ECM sends low power periodically to the positions where the car should have incandescent lights installed. The power isn't enough to make an incandescent bulb flicker however it will with an LED because of how energy efficient they are. The only way around this problem is coding. So that said it's actually the car that causes the flickering not the LED's, they work better then their suppose to.
      04-28-2014, 11:05 PM   #19
s4mzxc
Drives: f30
do you have reverse light and the brake light pic?
      06-22-2014, 10:52 AM   #20
RSnic
RSnic's Avatar
658
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
First off, if anyone wants to go with European tail lights, the part number for the kit (left & right) is 6321 731845KT; ECS Tuning has it for $469.
Am a little confused by this thread. Since I like amber rear turn signals, am trying to come up with a little less expensive solution. I would think that if I got an amber bulb (perhaps LED) and replace the turn signal bulb with it, the turn signal would appear amber. Having said that, thought there are two bulbs in the turn signal housing, but there are three functions: brake lights, turn signals, & tail lights. Do one of these P21W bulbs only work the turn signals? If so, that would be the one to replace
So, which bulb to replace and will an amber bulb appear amber through US tail light assembly?
Appreciate any help
Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      06-22-2014, 01:59 PM   #21
RSnic
RSnic's Avatar
658
I assume you changed out one of the bulbs in the tail light on the rear fender. Which socket in the tail light do you install these bulbs in?
Thanks
Al
Retired: 2014 328i
BMW CCA
      06-24-2014, 08:37 PM   #22
Steve33
Steve33's Avatar
No_Country
50
Drives: 2018 SQ5
I have one of those in my thread here http://f30.bimmerpost.com/forums/sho...d.php?t=996012
Thanks
The blinkers are on the outside light on the top. Brakes are the bottom on the outside and inside tail light housings. Reverse are on the top of the inner tail light
Hi,
Appreciate any help
Thanks
WTS302RAY on bimmian is the rear amber tail light bulb. I don't think it'll do much though as far as color.
http://www.bimmian.com/WeissLicht-LE...W-F30-3-Series
Tags
bulb, led, spektrum, weisslicht
f30post
