BC Coil camber plate removal??
12-27-2013, 01:02 PM | #1 |
Rep 54
i get a lot of noise (bumping) at low speeds/parking lots/east coast roads from the rear that i attribute to the bc camber plates....i don't think these are required and i'm thinking of removing them (replacing with oem mounts) but wanted to see if this makes sense before making anything worse. i'm only running -1.5 camber in the rear so that should be within stock tolerances right? Any help or suggestions are appreciated!
PTF Pro Tuned l BMS DCI l ETS FMIC l VRSF DPs
HAT L4SE Carbon l HAT L1V2 l Jehnert XE200 l Arc Audio Arc 12 l Arc Minis l Audison bit Ten |
