12-22-2013, 07:36 AM | #1 |
3489
Rep 9,709
The great virtual F30 race
Seeing as I am on my Christmas break and have a chance to manually input all the engine power, weights, gear ratios, wheel sizes, etc into some software called CARTEST, I've come up with some interesting analysis.
Cars in database (so far):
Note: Unless described differently...all cars M Sport spec, All cars ZF8, all cars sDrive, all cars 19", etc. Also: Driver weight 90kg's with 20Kg of Fuel (which equates to about 28l of petrol or 24l Diesel), Dry tarmac, optimised Launch. Here are a few 'virtual' acceleration plots. The software can also plot usability in a certain gear, lap times for well known tracks, roll ons from x speed, etc. Just ask if you want me to do comparisons. Attachment 954756 Last edited by NISFAN; 12-22-2013 at 12:44 PM.. |
12-22-2013, 08:20 AM | #3 |
292
Rep 1,121
Would the weight of AWD make that big a difference I can understand the better traction for initial few hundred metre , but looking at it in that example it would be 330d standard all the way
12-22-2013, 08:21 AM | #4 |
Rep 33
The question is, what power outputs have been used in the calculations - BMW's or what they have measured on rolling roads? Ignoring xDrive for a moment I can't see an sDrive 335i which is both lighter and more powerful being such a small amount faster at getting to 1000m.
The results differ from what BMW quotes to 1000m as well. 330d 25.8 sec E92 335i 24.4 sec |
12-22-2013, 08:31 AM | #5 | |
3489
Rep 9,709
One thing to note though, this software (the way I have configured it) assumes optimum everything. So wheelspin control, gear change RPM's etc. The xDrive cars also have a Launch control set at 3,500rpm, vs 2000rpm on the sDrives. |
12-22-2013, 08:34 AM | #6 |
3489
Rep 9,709
The 335d is 90kg's heavier than a 330d sDrive. That is significant. Over 100kg's heavier than a 335i.
12-22-2013, 08:41 AM | #7 | |
3489
Rep 9,709
335i figures are from a different dyno done in the US, but I have seen similar results in the UK for 35i engined cars. Car weights from BMW. Note that the real output of a standard 330d is less than 30hp lower than a 335d. I need to check, but the torque band might be slightly better too. It is the amount of power under the curve for a set gear that determines performance. Observation: The 335d uses similar ratios to the 330d, which might not be optimised for the engine output. Optimum gear change speeds for the 335d are around 4,500 in each gear. Quite a bit lower for the 330d. |
12-22-2013, 08:50 AM | #8 |
3489
Rep 9,709
Individual acceleration data for 335d and 330d shown below. I think it is showing the 330d as being a little faster than it is. Only perhaps 0.15 sec to 100km/h (62mph).
At the same token, it might be a little unfair to the 335d by a few tenths to 62mph. Note that these are full launch runs. A 'mash the pedal' start won't produce the times, but imagine the 330d RWD will suffer less from wheelspin. Last edited by NISFAN; 12-22-2013 at 12:47 PM.. |
12-22-2013, 11:10 AM | #10 |
83
Rep 1,322
Great work NISFAN
When I get some downtime over Christmas I'll take a closer look. Meanwhile, how does this compare with the analysis on this site?: http://www.automobile-catalog.com |
12-22-2013, 12:19 PM | #11 |
32
Rep 652
Good stuff Nisfan, I know my 330 s drive is rapid anyway, the first solo spirited drive for a while today and come back with a massive smile on my face. Cannot wait to PPK it, I really think its going to set it off!
12-22-2013, 12:55 PM | #12 |
3489
Rep 9,709
OK, I found the glitch that was affecting the xDrives. Basically....the software doubles up driveshaft and diff losses for AWD's. Whilst technically correct, the data I input was derived from Wheel horsepower, so it was having a bigger effect than it should have. I have now uploaded the files with modified AWD losses.
The second glitch, affected both 335d and 330d. In joining up the dots on the horsepower graph, the software uses spline averaging. As anyone knows when using spline, it works well for arcing type graphs, not for S shaped graphs that (especially the 335d) both 330d and 335d had. It had given the 330d a bulge above it's actual power, which was making the 330d a little faster than it should have. I have smoothed the curve to give a more realistic figure for both engines. |
12-22-2013, 01:07 PM | #14 |
498
Rep 1,502
Drives: M4 CP SSII/SS
Very interesting NISFAN and thanks for posting.
As this is purely theoretical, can you do a 335d s-drive, assuming the 330d s/x weight delta?
Current: F82 CP SS/SS
12-22-2013, 01:43 PM | #16 | |
3489
Rep 9,709
Good idea I've kept the additional 20kg's weight of the 35d engine (extra turbo and oil cooler ???) but taken off 70kg's of AWD gear. Perhaps a clue as to why there is NO 335d sDrive |
12-22-2013, 01:45 PM | #17 |
3489
Rep 9,709
12-22-2013, 01:49 PM | #18 |
480
Rep 2,324
How much more does the x-drive weigh?
Parkers says its only 20kg heavier? I can't believe that! How can the 330d ppk be faster than the theoretical 335d s drive? |
12-22-2013, 02:03 PM | #19 | |
3489
Rep 9,709
335d = 1705kg's 330d = 1615kg's BMW Technical pages Believe it or not, the 330d PPK actually has a better power/torque shape than the 335d. The 9hp extra that the 335d gives occurs at a much higher revs where engine torque is lower. It is also hamstrung by using the same diff ratios as the 330d. These graphs can be seen here.335d dyno run |
12-22-2013, 02:10 PM | #20 | |
480
Rep 2,324
12-22-2013, 02:27 PM | #21 | |
45
Rep 1,486
So the graphs are really just a theoretical times for your car standard and PPK'd & GTsussex's car, and some graphs from a 335i. Why don't you put all the BMW published figures in, to see the times? As we know not all cars produce the same power as published.. some better some worse. I know from the times I've seen the 335d posts the same 0-1000m time as the M135i (23.8), and it's definitely faster than the 330d. I think that's a better measure since it's over a better distance.. 0-60 times are not a great measure |
12-22-2013, 02:46 PM | #22 | |
3489
Rep 9,709
I used real figures because the BMW figures are nuts. Set by marketing by the looks of it. Yes 1km is a better yardstick than 60mph, that's why I included it. |
