how to torque rear suspension?
12-20-2013, 02:55 PM | #1 |
Rep 98
ok so I have had one other post on here about this issue. the rear passenger side of my 2010 e92 335i mt where the front upper control arm bolts to the wheel knuckle. that bolt has now snapped 3 times! the first time on stock sport suspension and no other mods, I replaced the control arm as well as all struts with kw coilovers v1, and it happened again. first 2 times happened while slamming into second gear. now last night it happened going over a bump at about 10 mph. it was also very cold all of these nights.
Now my question is how the hell do I get the torque specs correct on this area. in order to torque down the bolts on those top 2 control arms (or any of them ) the car must be under load. so i put load on the suspension but i can only get to the upper rear control arm with a torque wrench . once load is on the car it is impossible to fit a giant torque wrench in the little space that's left. has anyone replaced any of these control arms?what was your method to getting these bolts torqued correctly while under load? please and thank you ..im really getting tired of swamping bolts out of my suspension at all hours of the night in the cold lol |
12-20-2013, 03:16 PM | #2 |
41
Rep 642
Crowsfeet, and/or box-end wrenches on one end with a ratchet drive end on the other http://www.amazon.com/Stanley-J5100-...=pd_sbs_auto_4. http://www.amazon.com/TEKTON-2585-2-...ef=pd_sim_hi_2 . You'll have to re-calculate the torque though.
But honestly, I just go with gud'n'tight for my car. I am very comfortable with how fasteners feel when they are "torqued". I would not recommend it to you, just go with the adaptors. |
12-20-2013, 04:33 PM | #3 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
You can load up the suspension by putting it on stands, and lifting from under wheel carrier with a jack until the car just lifts off the stands. That should hopefully give you enough access to fit a wrench in there.
12-20-2013, 05:31 PM | #4 |
56
Rep 1,464
Drives: 2009 BMW 335xi
With the car on jack stands and the wheels off you can jack up each side of the suspension independently until the suspension is at ride heigh (lower control arm parallel with the ground). Tighten the bolts and repeat as needed for each wheel.
12-20-2013, 07:35 PM | #5 | |
Rep 98
12-23-2013, 07:23 AM | #6 | |
146
Rep 1,160
HERE |
