Castor adjustment via Tension Strut bushing?
12-19-2013, 05:53 AM | #1 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
Hey folks,
I was on Whiteline's site looking at their bushings and noticed they have a front tension strut bushing which can be used to adjust castor. There's not a ton of direct discussion of castor on our site. Mostly "it's not adjustable" or "use camber plates that have castor adjustment". So this option seemed interesting, or, at least different. Here's a link to the product http://www.whiteline.com.au/product_..._number=KCA430 there is an install pdf on the page to see how it works. Anyway, curious about any knowledge or opinions from our suspension experts. |
12-19-2013, 09:33 AM | #3 | |
Diamond Geezer
212
Rep 2,385
12-19-2013, 09:51 AM | #4 |
just another bmw douche bag
195
Rep 3,640
caster is on a different axis of the suspension than camber is. if you increase front caster, static camber is not affected, but you do increase the negative camber gain on the outside wheel/tire as the wheels are turned.
so usually this is a good thing, though it's only 0.5 degrees of additional castor. You'd have to take some measurements with a camber gauge (or do some calcs) to see how much additional negative camber it adds at X steering angle. if you are upgrading bushings, it might make sense to throw these in, but camber plates would probably give you more adjustment as well as being easier to adjust. |
12-19-2013, 09:57 AM | #5 |
226
Rep 2,387
No I mean that, from the installation diagrams, it appears these affect camber caster and toe at the same time. It is not clear exactly how. IOW it is not a pure caster mod.
The tension strut sits at roughly 45 deg angle to the bottom of the hub, relative to straight ahead. Making that slightly longer or shorter via an eccentric in the inboard point the angle of all three measurements changes. Or at least it looks that way. To increase caster only you'd need to find a way to tilt the top of the strut straight back at the top (via camber/caster plate) or push the bottom straight forward at the hub. At the bottom it is constrained by the other link and the tie rods, so it is going to rotate/tilt in some more complex way. |
12-19-2013, 10:22 AM | #6 |
Diamond Geezer
212
Rep 2,385
thanks guys. Sounds like a camber/castor plate is a more robust solution.
12-19-2013, 12:28 PM | #7 | |
226
Rep 2,387
The rear susp has what are called camber and toe links, but if you've ever adjusted them yourself it is obvious they affect each other. |
12-19-2013, 02:53 PM | #8 |
195
Rep 3,640
right, but they would only affect toe if you didn't get an alignment after the install, and you should always have the car aligned after changing suspension pieces. Any toe change would be adjusted back to your original setting.
It may slightly affect static camber very slightly, but since it's on a different axis than the lower control arm, the effect would be minimal. either way, I think we both agree that there are other mods to do to the suspension that would be more beneficial than these bushings, and also offer more adjustment. |
