Fast street/track alignment specs
12-18-2013, 11:05 AM | #1 |
LCI'd
257
Rep 819
Hi,
looking for specs for a 2009 335i E90 LCI... I'm thinking: Front camber -0.8 deg both sides Front toe -0.09 deg total Rear camber ??? Rear toe ??? Any advice welcome... |
12-18-2013, 02:26 PM | #2 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
As for the rear I would go no more than -1.8* of camber. That is kind of the standard for all cars, even cars that are used on the track. -Mike |
12-19-2013, 11:06 AM | #3 |
LCI'd
257
Rep 819
Hi,
car is stock, with alignment pin removed... Minimum stock toe on the front is 0.04 deg toe IN... do you think that is a good idea? The range is quite large, for the front from 0.04 to 0.4 toe IN... How much toe for the rear? Minimum within BMW tolerance is 0.3 deg toe IN |
