BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Koni Yellow (how many turns do I have??)
      12-16-2013, 10:28 AM   #1
e9012345
29
Drives: e90
Just popped on a set of Koni Yellows on my car (coupled with H&R sport springs)..
The rears are set to 1 turn from soft
The front is set to full soft (to break them in - I'll dial them in next week)
My question is how many turns do I have in the front and in the rear from full soft to full stiff?
6MT Sport Pkg | BMW Perf. Pedals | BMW Perf. SSK | CF Steering Trim | BMW Performance Black Gloss Grilles | M3 Rep Bumper | Muffler Delete 2.5"| Charcoal Delete + K&N Drop In | CDV Delete | Clutch Stop | Active Autowerke Stage II Tune | H&R Sport Springs | Koni Yellow Shocks/Struts | 18" Gunmetal CSL Reps | BurgerTuning Spacers | Staggered Ventus V12's | ATE Super Blue & Hawk HPS | Blacklines | GP6K Angel Eyes
      12-16-2013, 12:52 PM   #2
ajsalida
ajsalida's Avatar
226
Drives: 95 M3, 02 R1150GSA, 09 335xi
Umm. Experiment with the front and see how many you have should be a bit over 2, like 2.25 to 2.5. BTW I have read you are not supposed to run these fully turned one way or the other they may get damaged. So if I were you I'd run them 1/4 to 1/2 turn off full soft in front to start with.
The other thing is they are not linear WRT turns so if you have say 2.5 full turns lock to lock really only the middle 1.5 or so range of turns adjust anything.
      12-16-2013, 02:15 PM   #3
cvc 22349a
cvc 22349a's Avatar
164
Drives: 335i
+1 ^
Try 1.5 turns from soft up front OP. The rears sound about right for those springs.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS
      12-16-2013, 07:14 PM   #4
e9012345
29
Drives: e90
So my other problem is that.. the front strut bar is covering the adjustment points for the front setup...
I'd have to remove the entire strut bar to adjust... godamn.. any way around this?
I'd use pliers.. but that wouldn't be too precise and I'm scared of ruining the adjustment clamps.
      12-16-2013, 08:15 PM   #5
thegrinchboy
thegrinchboy's Avatar
62
Drives: '11 335xi, '18 X1, '21 M2C
You should verify the range by going from full soft to full hard and then back to full soft with the set you have. Per Koni's website, you have a range of 2.5 front and rear. On the set that I received and installed in May 2013, I have 2.5 on the front, but only 1.75 on rear (2012 mfg date). Since then I have had one rear shock that was replaced by Koni USA (2011 mfg date, I think) and that had a 1.75 range as well. For the rear set up, I extrapolated the 1.75 actual range with factory stated range of 2.5 turns and ended up with .8 turn ~ 1 turn. For the front, I am at 1.25 turn from full soft.
Worthwhile to note I have UUC sways in front and rear, ZSP springs, and non-RFT
      12-17-2013, 06:10 AM   #6
ajsalida
ajsalida's Avatar
226
I use a small crescent wrench and turn in 1/4 increments or less. Memorize the visual position of the adjuster WRT the surrounding hole, or even mark the edge once you get it to full soft.
TCKline sells a tool, like a screwdriver with a slot in it. $20. You could make one, someone did here. Alternatively you may be able to use a 1/4" drive socket of the right size, on a U-joint. I have thought of this but never tried it.
In any case you do not need to remove the strut bar entirely, just undo the bolts near the shock pull it up a bit and that is enough to adjust carefully.
Again I would not get too carried away here, adjust the fronts down to 1/2 or so off full soft, see if that improves the feel. Since we are heading into winter, mess around til you find the right front setting, then take the rears off (once) and set them the same. Get used to that over the winter then by spring you'll have a better idea where you want to go if anywhere differnt.
      12-17-2013, 06:18 AM   #7
notnow
Bit by Modbug
258
Drives: F86
I set front and rear to full stiff minus 45 degree turn.
