KW V2 Install Suggestions
12-16-2013, 05:35 AM | #1 |
165
Rep 1,403
Drives: 06' E46 M3 ZCP
I am having a hard time tightening the front top strut nut on the KWs. The strut rod turns every time I attempt to tighten it. Anyone have any suggestions on how to do it?
12-16-2013, 06:05 AM | #2 |
Bavarian Idiot
29
Rep 183
12-16-2013, 10:27 AM | #3 |
687
Rep 2,770
Unless you have the special socket it will be tricky. My plan is to use a strap wrench to hold the strut rod while I torque the nut. I also found a passthrough socket wrench at Lowes that would work but that was like $40 with all the parts. Just be sure to apply the proper torque here. It is important to get this right.
12-16-2013, 12:40 PM | #4 | |
147
Rep 1,319
2016 F80 M3 BSM with Black interior DCT/Driver Assistance/Executive/LEDs/Adaptive/Black Wheels
2014 F32 435i xDrive AW/CR 2014 F25 X3 M-Sport Carbon Black 2011 e92 335is 2007 X3 122k miles 2006 e90 330i 132k miles |
12-16-2013, 12:47 PM | #5 |
91
Rep 817
You can also buy a cheap socket and use an angle grinder to cut out the face of the socket to make it look just like the special socket needed....that way you can still use a tourque wrench. You can also use an impact gun but it's not recommended and you won't be able to tourque it properly. I think most shops use the impact though.....
12-16-2013, 01:37 PM | #7 |
147
Rep 1,319
Couldnt that damage the strut?
12-16-2013, 03:49 PM | #8 |
687
Rep 2,770
Seriously guys, do not install these nuts with impact drivers!!!! They need to be torqued down properly. Do you really want your strut coming apart on you on the freeway?!? Also, you realize there is a bearing on your strut upper mount right? If you hammer this nut too tight you can destroy this bearing and you need that to work to allow your steering to move.
The spark plug socket idea works too but you should use a hex bit on your torque wrench so you know you have the right torque applied. |
12-16-2013, 05:27 PM | #9 |
165
Rep 1,403
Thanks for all the responses. No way will I use the impact wrench. Going to look into the home-made approach.
12-18-2013, 01:47 AM | #10 |
18
Rep 268
worked fine for me.. although i was using a makita which is only about 80lb/ft max. you basically do a series of burst fire on the wrench and it slowly tightens it. when it is too tight it will spin the strut rod with the bolt so there is really no worry to over tighten.
