What item is this from our car?
12-11-2013, 11:33 AM | #2 |
36
Rep 311
Not having a size reference, it looks like the dust cap that goes over the rear shock in the trunk. Its under the trunk liner, fits in a hole in the sound deadening.
12-11-2013, 12:07 PM | #5 |
1071
Rep 4,856
Thanks folks! Does any one know the part # for this piece?? I tried entering all the #s that I see on the piece in getbmwparts.com but nothing came up...
There are 3 sets of #s: 5171 7075841 119867 |
12-11-2013, 12:23 PM | #6 |
36
Rep 311
51717075841
I think its the Protective cap wheelhouse http://realoem.com/bmw/showparts.do?...59&hg=51&fg=80 |
12-11-2013, 01:08 PM | #7 | |
1071
Rep 4,856
12-11-2013, 01:29 PM | #8 |
36
Rep 311
I wouldn't do it unless I had too. To install it, you have to remove all the plastic trim pieces on the bottom of the trunk opening, remove all the carpeted liners in the trunk just to get to it. There one on each side so without knowing which one is missing, you would remove both sides. The liners are pretty stiff and you wont be able to just loosen them and snake your arm behind.
You should be able do a search on replacing rear shocks that walks you thru removing all the liners in the trunk. see pic after step 6, the back circle in the picture is that part. http://forums.bimmerforums.com/forum...stallation-DIY Last edited by critical05; 12-11-2013 at 01:40 PM.. |
12-11-2013, 01:58 PM | #9 | |
1071
Rep 4,856
