F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Noisy Rear........
proTUNING Freaks
      12-10-2013, 04:43 AM   #1
DMI
Drives: F30 318D
Noisy Rear........
Good Morning. My 3 month old 318D, is producing a loud metallic click from the rear offside quarter when turning at low speed such as coming out of a junction. It doesn't happen when cornering and only occasionaly when going over speed bumps. Theres nothing loose in the boot and it doesn't seem to matter if its warm or cold. I’m not sure if its suspension or its coming from the boot lid when the car is in twist/torsion. I remember having something similar on a hatchback which was cured by adjusting the hinges but obviously this isn’t a hatch. The cars booked in but I bet it wont perform on the day. I’ve browsed the net and there are various threads that sound similar but not quite the same. Any clues/ideas? Thanks
      12-10-2013, 05:18 AM   #2
jayakrishnanv
jayakrishnanv's Avatar
81
Drives: BMW G20 M340d
have you checked if there is any wheel nuts loose? When you take it for the check up by the dealer try to get it tested and confirmed by the dealer by replicating the noise and else they will say they haven't heard so in their test drive.
In my old E46 this was due to the rear shock mount being loose. In a E90 which we were planning to pick we had this similar noise which when done with a inspection by RAC engineer turned out to be the driver side rear output shaft front the diff. nothing to be scared off but make sure its well noted by the dealer and these can be rectified all the best
Cheers
Jay
      12-10-2013, 11:33 AM   #3
Firecrest
11
Drives: F30 318d
I've got a 318d, not same issue as yours but I get a noise on acceleration, a kind of gurgling, rattling noise. Been told it normal but I think that's rubbish, do you get it? thought I'd ask as not many 318d members around
      12-10-2013, 03:02 PM   #4
mgarvey
mgarvey's Avatar
30
Drives: Renault Megane
Not had this on my 318d. Closest I can think of is last week when I had a stone caught in my wheel, but it only lasted a few hundred metres before it worked its way out.
Current: Skoda Octavia Scout 4x4 DSG
Previous: F30 318d Sport, R56 MINI Dooper 2010, E93 325i M-Sport auto 2007, E91 320d SE 2005, E46 318Ci Coupe 2002
f30post
