Question about M3 control arms and tension struts
12-09-2013, 01:52 PM | #1 |
630
Rep 1,649
Hello all. I am thinking about DIY front M3 arms and have a question about the resulting alignment. After installing the arms does it have more toe in or more toe out? I am guessing toe in given the knuckle was moved further out and the tie rod length stayed the same, but I am not sure. Any idea of a rough amount to adjust the rods so I can drive it to the shop from my place? It is about 10 miles. I assume that if I lengthen or shorten each rod the same amount of turns after install the car should be driveable.
12-09-2013, 01:58 PM | #2 | |
38
Rep 864
Drives: '08 E92 335i
12-09-2013, 03:23 PM | #3 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Like Dallas said if you eyeball it and get it to an alignment shop rather quickly you should be alright!
-Mike |
12-10-2013, 01:15 PM | #4 | |
630
Rep 1,649
thanks! |
