Winter Tire Square Set up
12-09-2013, 10:26 AM | #1 |
80
Rep 1,076
Drives: 07 335i e93 6MT
Hey guys, We were hit pretty hard yesterday with snow and I am desperately in need of winter tires. I've read here that a square set up is the way to go on stock 189. I've also read that you guys are running 225/40/18 all the way around. I just talked to a tire shop and they said that they cannot put 225 on my car since the rear is 8.5. They said they have a 245/40/18 and that I should go with that. Can I get someone to chime in and confirm or deny?
I'm also looking at the blizzak ws70. Good tires for heavy snow conditions? Thanks in advance.
07 BMW 335i E93 6MT (Praying neighborhood doesn't get flooded...again) 04 Infiniti G35 Coupe 6MT (Flooded) 08 Audi TT 2.0T DSG (Flooded) 03 Subaru WRX 5MT (Flooded) |
12-09-2013, 12:45 PM | #2 |
163
Rep 2,823
225/40/18 with 245/40/18 would be bad combination. Diameter difference over 2.4%.
You can easily use 225/40/18 on 8 and 8.5 wheels and most guys here seem to use the winter setup like that. The rear tyre just settles little bit differently on the wheel. Narrower tyre is also better at snow. Here is comparison picture of 225/45 on 17x8 and 17x8.5 http://www.e90post.com/forums/showthread.php?t=85623
12-09-2013, 01:02 PM | #3 | |
General Nuisance in a Private Conveyance
77
Rep 1,907
Drives: like it's rented
Check out this link to determine min/max rim size for each tire size: http://www.rimsntires.com/specs.jsp Here is my ride, with 225/40 on the 8.5 inch front wheels, with no stretch, whatsoever:
BMWCCA Member # 414198 |E90|SGM|6MT|Premium|Cold|Sport|Tint|LCI MSport Conversion|MTech|Blacklines|219M|PSS|Quaife|Helix FMIC|M3 Suspension|Megan Racing|GC Camber Plates/Coilovers|Eibach 440/800#|AR Catted DP|Cobb AP|StopTech Drilled/Slotted|SS Brake Lines|DWS Quaife Review: http://www.e90post.com/forums/showthread.php?t=311570 |
12-09-2013, 01:11 PM | #4 |
163
Rep 2,823
In fact 225/40/18 is approved to 7.5-9 widths. Standard is 8.
12-09-2013, 01:21 PM | #5 | |
Guest
Rep n/a
Drives:
OP - the idea of running 225/40/18 on both 8 and 8.5" wheels for a square setup has been discussed at least 10 times on the front page alone...do a search. |
12-09-2013, 01:24 PM | #6 |
BimmerPost Supporting Vendor
2045
Rep 25,989
If your tire shop is telling you that, you should find a new tire shop. They don't know what they're talking about.
http://www.tirerack.com/tires/tires....WS70&tab=Sizes If you look at the rim width range for this tire, it's between 7" and 9", so an 8.5" wide wheel will be perfectly fine.
VMR|Wheels | 714.442.7916 |
12-09-2013, 03:41 PM | #7 |
80
Rep 1,076
Oddly enough I got more confused, when i called tire rack and they said the same thing that 225/40/18 won't fit in the rear. After reading this your guys response, I called back to tire rack and the guy I talked to stated that the last guy didn't know what he was talking about. lol. So I placed an order. Feel better now. Thanks.
12-09-2013, 06:43 PM | #8 | |
255
Rep 2,547
12-10-2013, 01:11 AM | #9 | |
163
Rep 2,823
12-10-2013, 10:32 AM | #10 | |
80
Rep 1,076
I did go with the 225/40/18 with the second guy I spoke with who pretty much said the first guy was an idiot. lol.
12-10-2013, 11:12 AM | #11 |
77
Rep 1,907
Yes, those are OEM Style 219M wheels, and they certainly fit a non-M, pre-lci 3-series vehicle, with minimal to no modifications to the rear fenders, although many incorporate a fender roll, just to be sure. The specs for my ride are:
Front: 18x8.5, ET29, Michelin Super Sport @ 225/40/18 Rear: 18x9.5, ET23, Michelin Super Sport @ 255/35/18
12-10-2013, 11:21 AM | #12 |
163
Rep 2,823
At this point i will say that E90 Lci will definitely need fender roll to rear to fit those 18x9.5 et23, because it's the same as 18x9.5 et15 on pre-lci. Also would go no more than 255/35/18 tyre at rear. Front is no problem.
12-10-2013, 04:47 PM | #13 | |
Moderator
369
Rep 4,745
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
12-11-2013, 01:48 PM | #14 |
80
Rep 1,076
No worries, you guys came through in the end. I'm getting them installed today. Can't wait to feel invincible in the winter again. lol
12-12-2013, 11:37 AM | #15 | |
89
Rep 3,732
Drives: BMW S1000XR
BMWCCA member |
12-12-2013, 11:55 AM | #16 |
89
Rep 3,732
Drives: BMW S1000XR
Btw...had the WS 70s on my 135 and I thought they were great in snow but sucked balls when the roads were dry. Handling was not good at all. I switched to the LM 32 performance winter tires this year. They work pretty good in snow and a ton better when the roads are dry like today.
BMWCCA member |
12-12-2013, 12:00 PM | #17 |
80
Rep 1,076
I ended up going with the Dunlop Winter Max. The ride is a lot softer than my nitto summer tires on 19s. Although I haven't gone too crazy since I've only had it on since last night, handling seems ok. I don't plan on going too crazy in the winter so this should be good. I've read another user review from here that these tires do very well in the snow so that's what I'm mainly looking for.
12-14-2013, 10:34 AM | #18 |
Ikea enthusiast
334
Rep 8,140
Drives: '07 E92 335i
Tire shops will be hesitant or will just outright not put anything on other than recommended OEM sizes because of liability concerns. My first winter with winter tires I went to a Firestone to have 225/40/18s put on my staggered 189s and the guy there literally said "you won't even make it out of the parking lot with that before it explodes"
I've been running that setup for the past three winters with no issues whatsoever. My Blizzak LM-60s stretched a bit in the rear on the 8.5" wheel, but I have Michelin Pilot Alpin PA4s this year and they're just about perfectly flush with the edge of the wheel in the rear.
