Anything more comfortable than KW Street Comfort? Maybe spring + dampers?
12-08-2013, 08:42 PM | #1 |
231
Rep 1,473
I think it is time to change out my current suspension setup. The car will probably not see anymore track days to justify the current setup (JIC Coilovers).
I am looking for the most comfortable setup with a reasonable drop. Is there anything more comfortable than the KW Street comfort coilovers? How about Eibach + Koni Yellow/FSD? H&R Sport + Koni? Something else I am not thinking of? I was leaning towards Ohlins but can't justify the cost right now. Thanks! |
12-08-2013, 09:16 PM | #2 |
28
Rep 544
St coils since you live in Cali u can adjust your height exactly the same as kw v1,other then the fact that its made out galvanized steel which would corrode in salt. Or you could go with Joni yellows swift aprinfa plus m3 front control arms and links possibly m3 rear sub frame bushings to.
VMR VB3 // Mtec v4 AE //Nokya 7000k // M-tec LED plate lights // OEM blacklines // 20% window tint // Cyba air scoops // K&N + charcoal filter delete // BMS Powerbox // front splitters // Hamann front lip// M-tech trunk lip // Magnaflow custom // ER SS brakelines // KW V1's // RS tecknik spacers // H&R spacers |
12-08-2013, 09:27 PM | #3 | |
231
Rep 1,473
I already have most of the M3 parts, which in my opinion don't do anything for comfort. I just want the most comfortable ride with an aesthetically pleasing drop. I actually think the Eibach pro kit is a decent enough drop so I would consider those. |
12-09-2013, 12:32 AM | #4 |
1254
Rep 4,088
SCs probably make the most sense for your performance and budgetary needs. If ohlins are outside of your budget then DA tcklines probably are too...
12-09-2013, 01:17 AM | #5 |
164
Rep 2,556
To answer the title of your thread, no and I've run a few different spring/damper combos.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
12-09-2013, 01:56 PM | #7 |
164
Rep 2,556
Koni FSD and Sports with oem Sport springs and Koni Sports with BMW PS springs and bumpstops. The best of those for ride quality was probably oem sport springs with Koni Sports.
There's just more compression travel with KW SC prior to bumpstop contact than any of those spring/shock combos. The springs are stiffer so the car follows road irregularities more but bumps are absorbed by the suspension more so than being transmitted to the chassis. BMW uses bumpstops as a secondary spring whereas KW uses them to prevent the dampers from bottoming. But if you lower the car too much with KW you'll lose that extra compression travel and ride quality will get harsh as it does with lowering spring/shock combos.
12-09-2013, 04:04 PM | #8 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
-Mike |
12-10-2013, 08:42 AM | #9 | |
231
Rep 1,473
Is there a significant difference in the strut tube diameter on the Koni's vs KW? Anything wider than what I currently have is going to rub on the inner lip of my rims. |
12-11-2013, 01:41 PM | #13 | |
3847
Rep 54,376
Drives: F80 M3
-Mike |
Tags |
comfort, comfortable, koni |
