Camber
12-05-2013, 09:28 PM | #1 |
Quiet till poked
99
Rep 1,176
Camber
Hi, can someone tell me what a good range to keep negative camber in and what the stock camber is at?
Reason I'm asking, is because my mechanic told me that I've got too much negative camber both front and rear to the point where the inside tread on my tires is almost gone already. The tires are only a year old. I am lowered on KW V1s and running 225/40R-18. I'd appreciate if someone can teach me about this, as I'm not familiar with this and I love learning about the car. Thanks. |
12-05-2013, 09:32 PM | #2 |
Wang D.D.S.
185
Rep 7,057
BMW designed its cars to have negative camber man, it's the TOE that really determines how fast your tires wear off. The max camber in the rear is only about -2.7 and that's not a whole lot IMO.
12-05-2013, 11:10 PM | #3 |
Quiet till poked
99
Rep 1,176
How can I find out how much negative camber I have? If it's within an acceptable range, then I'll just leave it. However, my mechanic, works at Ticher, recommended getting camber plates or control arms. So, I figured I was outside of an acceptable range.
12-05-2013, 11:18 PM | #4 |
Wang D.D.S.
185
Rep 7,057
Camber plates are for MORE CAMBER not to reduce it, find out your camber by having your car get on the alignment machine man.
12-06-2013, 12:35 AM | #5 |
Quiet till poked
99
Rep 1,176
12-06-2013, 07:06 AM | #6 | |
146
Rep 1,160
View THIS Yes, your neg camber is too high. HERE is a handy Internet based guide to E9x alignment specifications. Stock suspension components have adjustable Toe and Camber. If you're lowered much more than 3/4" below Sport suspension ride height, you likely got trouble. Solutions: [1] Don't leave the performance envelope. Overly lowered may satisfy your feminine side; ain't gonna perform. Raise your ride. |
12-06-2013, 11:28 AM | #7 |
just another bmw douche bag
195
Rep 3,640
12-06-2013, 03:58 PM | #8 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Here is the deal. When you slam a car you are automatically giving it a considerable amount of negative camber. Even race car drivers (for sport class) will have their rear camber dialed in at NO MORE than -1.8*. Anything more than that is pointless and hurts the car in obtaining grip coming out of corners.
With that being said you can NEVER have enough camber in the front to be honest. Some people say best is _____ but in all honest I max out my camber plates at all times. I really don't wear tires too quickly because I am not an aggressive street driver. Hope that is some food for thought. -Mike |
12-06-2013, 10:40 PM | #9 | |
Quiet till poked
99
Rep 1,176
I'm gonna get an alignment ASAP and find out what specs I'm currently at. Based on your solutions, I'll most likely just raise it as I'm going to turn this set into a winter setup. I just bought a set of 19s. Based on what I've read on the forums here, these two setups are pretty common and well liked. • 19x8.5 5x120 ET32 | 225/35-19 Front or 235/35-19 Front • 19x10 5x120 ET38 | 265/30-19 Rear or 275/30-19 You can call me a spirited driver, but not overly aggressive. Before getting the KWs, my Pilot Sport A/S Plus tires lasted for quite awhile. I want to keep the camber street friendly, as I do not track the car at all and don't plan to. I'll post up the alignment spec sheet whenever I get it done. Hopefully next week. Thanks to all for the info, I appreciate it. |
12-07-2013, 02:34 AM | #10 | |
146
Rep 1,160
Toe's important, but I assumed it was adjusted good and thrust angle was zero. Prob an over-reach, but hey. Lowered rides are all about camber - toe's easily fixed. |
