What next?
12-03-2013, 11:39 AM | #1 |
34
Rep 280
I've got a 2006 330i w/65k with sports suspension and Eibach pro springs(8k miles). Right now I have Michelin PSS on all fours and through corners it holds very well but wallows and rolls from side to side.. body roll? . For Christmas I'm looking at sways, strut bar, and shocks. I've seen stuff about M3 lower control arms too but I really don't know whats recommended. I'm about to replace lower control arm bushings but I don't want to spend the money if changing to the M3 control arms is really worth it.
Basically I'm just a little confused on what things it should get first, and what things will give me the greatest improvement. thanks!
2009 E82 135i 6MT FBO
12-03-2013, 12:04 PM | #2 | |
146
Rep 1,160
Your best result is: LSD first - required for rear M3 sway anyway Do rear subframe bushings when M3 sway installed. Vital! Your rear no longer disconnected.... |
12-03-2013, 12:07 PM | #3 | ||
34
Rep 280
12-03-2013, 12:53 PM | #4 | |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
Strut bar won't fix roll issues and from what I heard from many different BMW mechanics is the strut bar is mainly for looks as our cars are very stiff already. I would skip the LSD because our cars don't put down the same power as a tuned 335i so traction issues isn't such a big deal with our cars. |
12-03-2013, 01:04 PM | #5 | ||
34
Rep 280
12-03-2013, 02:31 PM | #6 |
705
Rep 2,605
12-03-2013, 02:46 PM | #7 | |
34
Rep 280
12-03-2013, 04:02 PM | #8 |
252
Rep 1,157
65k on shocks. Get new shocks.
Then go from there. I am firmly in the bilstein camp. Control arms are very fine. Your bushings will be getting tired. Instead if rebush get new arms. Presto whammo. Then do sways and sub bushing. My sport springs interact fine with the bils. In fact, they are great. I did drop hats up front for ~1/2" drop. At least at would be the order I would go. I did all mine at once. |
12-03-2013, 08:21 PM | #9 |
2030
Rep 2,672
don't touch sways until you learn more about suspension. If you want to reduce roll get good coilovers. Buy once and be done. You will want to change rear subframe bushings as well. They cause an unsettling feel when going over road bumps. M3 arms are not a must but a nice upgrade. You can get TRW parts a bit cheaper. LSD is very nice to have on wet roads and spirited driving.
GL |
12-04-2013, 12:31 AM | #10 | |
164
Rep 2,556
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
12-04-2013, 06:32 PM | #12 | ||
2030
Rep 2,672
12-04-2013, 06:59 PM | #13 |
34
Rep 280
Right now I'm looking at Bilstein B8's or the H&R cup kit
http://www.turnermotorsport.com/p-21...t-package.aspx What do y'all think?
12-04-2013, 07:04 PM | #14 |
255
Rep 2,547
I'd say since you already have the eibachs - get the B8 shocks. So many good reviews about the B12 kit. You can't go wrong with Bilstein shocks, ESPECIALLY on older cars because they improve all other parts of the suspension because they are more resistant to side ways forces.
12-05-2013, 11:59 AM | #16 | |
34
Rep 280
12-05-2013, 01:36 PM | #17 |
705
Rep 2,605
Basically yes!
Struts are on the front of our car, where the spring and the shock are a combined unit and actually part of the structure of the front end suspension. If you look closely at diagrams on realoem.com (http://realoem.com/bmw/partgrp.do?mo...23&hg=31&fg=10), the front strut actually mounts to the steering knuckle and bolts up to the strut tower above. The strut then becomes an integral structural component of your front suspension. Where-as the rear uses a standard shock canister mounted between the lower A-arm and the actual car, with the spring mounted in a separate location. http://realoem.com/bmw/partgrp.do?mo...23&hg=33&fg=30 Last edited by Volasko; 12-06-2013 at 10:30 AM.. |
12-05-2013, 02:13 PM | #18 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
I say the list should be as follows:
1) Replace shocks (Koni yellows) 2) Replace Subframe Bushings 3) Front Control Arms 4) Other M3 bits For a car with as many miles as you have, it is a good idea to hit maintenance issues that will ALSO improve performance, such as new shocks and subframe bushings. We carry all of those things if you are interested. -Mike |
12-05-2013, 02:51 PM | #19 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
regarding m3 subframe bushings, there is a budget alternative. Whiteline subframe inserts. Probably not as wonderful as the m3s but only $44 and easier install. Mine are on the way...
There is a DIY and review of them on 1addicts.com |
12-10-2013, 07:12 PM | #20 |
Rep 35
I have these on order too. What has your experience with them been?
2011 335is space grey, tint, black leather, 19" rims with 235/265 Michelin PSS, M3 control arms and tension struts, Bilstein B12 kit, Wavetrac LSD and Whiteline rear subframe inserts.
12-11-2013, 04:54 AM | #21 |
Diamond Geezer
212
Rep 2,385
01-01-2014, 09:24 AM | #22 | |
Diamond Geezer
212
Rep 2,385
