11-28-2013, 09:37 PM | #1 |
11542
Rep 11,128
Sporty watch
I have a Breitling but don't want to wear that when I'm working outside, at the gym, or on a bike ride.
My dad bought a Suunto as his sports watch and I like it. Any Suunto models you recommend? Or perhaps other watches? Do not necessarily need GPS. |
12-05-2013, 02:50 AM | #6 |
11542
Rep 11,128
12-05-2013, 06:58 PM | #7 |
Facetious
109
Rep 530
I have the Suunto Core Military (all black) that used to wear in the field (I work in Afghanistan as a contractor), but then I gave up on it and just wear my Sub as a daily watch. I don't wear a watch in the gym. I use the wall clocks there.
The Core is pretty cool though. I use it when I fly in helicopters, so I can track movement with compass and altimeter. A lot of people have problems with the buckle and bracelet breaking on it, but mine is in perfect condition.
Current: '15 BMW M4 (6MT), '08 HD Dyna Street Bob
Previous: '06 BMW 330Ci; '06 Mercedes CLK-350; '04 Acura TL A-Spec; '95 BMW 318ti; '92 Mercury Cougar; '94 Honda Accord |
12-16-2013, 01:24 PM | #10 | |
1042
Rep 5,660
Gym: I advise not wearing one during one's workout. If one must have a timer of some sort, go with something worn around the neck on a string (put it inside your shirt while jumping/jogging/bouncing around) -- most probably a stopwatch is what I'd suggest. Why? Well, first off, have you ever seen a gymnast wearing a watch while practicing or performing? Any other professional or collegiate athlete performing a physical sport?
Do you have some specific timing need besides knowing the time of day? If not any watch will do. Otherwise, a chronograph is likely the best choice. There are tons of chronos and they all work as advertised. I assume you are a vigorous, rough mountain biker for road biking wouldn't typically lead to any roughness that could affect the watch. Personally, I'd suggest something quartz as there are no moving parts to be affected by the vibrations of rough mountain biking. Any quartz that suits your liking will do. The one on the string suggested above would probably do fine so long as the trip isn't longer than the capability of the stopwatch. Another alternative is a watch/timer mounted on your handlebars. Working outside: Again, not knowing what your budget and specific needs are -- timing something, wanting an alarm to let you know when to stop, etc -- it's hard to suggest something specific. Quartz is what I'd suggest offhand because they can offer a variety of functions inexpensively; mechanical alarm watches from well recognized makers are quite pricey most of the time (well above your Breitling), though vintage and Russian ones can be had at sensible prices. The vintage ones will be dressier for the most part. Otherwise, again, if it's just a matter of telling time, you have a ton of choices in both the mechanical and quartz realms. Many folks like dive watches because they are quite often reasonably priced, have good lume and are durable by design and purpose. Among dive watches, I like Deep Blue. They offer very sensibly priced pieces and even their Fleet Admiral chrono is well priced. So, suggesting just one watch for all uses, I'd go with something from Deep Blue. Deep Blue Fleet Admiral: (~$600 - several colors available) Swap out the strap for a bracelet if that suits you better. Deep Blue Depthmeter Professional (~$600) Deep Blue Alpha Marine (~500) Deep Blue Pro Aqua (~$500 - multiple dial colors available) Deep Blue Master (~$400) Deep Blue Sea Ram (~$300 - quartz) Deep Blue have several other models as well. Most are priced below $600 and one is priced below $200. They also offer a wide range of bracelets and straps, including rubber, silicon, metal and cloth. All the best.
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
12-16-2013, 02:05 PM | #11 |
11816
Rep 23,187
i wear a watch almost all the time but wouldnt wear on any of those occasions. i like the suunto but the case size is pretty huge.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
12-16-2013, 09:51 PM | #14 |
1086
Rep 1,912
12-16-2013, 10:29 PM | #16 |
1567
Rep 2,665
Depends on what you are trying to accomplish, function or fashion. You need to time anything or just want to know the time? For exercise (running, biking, swimming, gym, etc.) and in the yard my wife and I use a Timex Ironman watches. Waterproof, durable, pretty cheap, lots of lap, chronograph, etc. features. For this watch I don't care a lot about how it looks and can't see any benefit of the $500 watch over the $60. Same reason I wear functional clothes and shoes at the gym, when running, or when in the yard, but don't worry about trying to look good.
We also both have GPS watches, I have a Timex, she a Garmin but unless you run I can't see a reason to get one. They are bigger, have less features, short battery life (recharging frequently) and more expensive. I have used my Timex GPS on the bike but the bike computers work just as well for a lot less money and hassle (recharge). I normally wear the watch on the bike even though there is a computer. For running the GPS is great.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
12-16-2013, 11:50 PM | #18 |
58
Rep 273
Drives: 330d touring F31, Z4 35is E89
Regards Thorsten
Our rides: Skoda Octavia Combi RS TDI DSG / company car // E89 Z4 sDrive 35is / my summer fun toy // F31 330d touring / daily driver of my wife |
12-17-2013, 12:34 AM | #19 |
1042
Rep 5,660
Audemars Piguet Royal Oak Offshore.
Cheers,
12-17-2013, 12:50 AM | #20 |
1042
Rep 5,660
I have to disagree with you on that. Had I known when I bought it what I know now, I'd have got the VC Overseas. Intrinsically, as a fine watch, there is nothing wrong with an AP RO or ROO. I have the RO and it's lovely, very well made, very beautiful, lot's of pedigree and super classy looking. It's an important watch to have if one is collecting seminal watches from major top tier makers. It's 1970s design aesthetic is quite trendy right now, as well it should be as it's one of the few things from that era that was well designed visually. What's wrong with the thing is that it wears far bigger and heavier than anyone would ever think it should. It's not uncomfortable, mind you, but it's a definite presence on the wrist, even more so, IMO, than any Rolex Oyster cased watch except maybe the Milgauss. Also, it's look -- especially the bracelet -- gives "dressy," yet it's not a dress watch. It's lume isn't stellar by any means. It's dual finish bracelet, though gorgeous, is going to show wear more than would a simple all brushed design. Lastly, I don't think it's a particularly tough movement running it. It's quite reliable, and of excellent quality and finish, but I wouldn't put it through too much punishment. I say this as the owner too of a Sub and a Breguet Marine (I keep it on a bracelet, but I have the blue rubber strap too). I'd sooner wear the Marine anytime I might opt to wear the AP RO just because it's more stylish and timelessly so. I also feel it a more durable piece. As for the Sub, it's just a tougher, work a day watch than either. It's clearly a sports watch whereas the other two straddle the line between semi-dress and dress. I didn't get a sense that the OP wanted to tool around -- biking, gardening, working out -- in a top end watch. If that's what he wants, it's a no brainer: Rolex Sub or just about anybody's dive watch. On the sliding scale of price points, I'd suggest Obris Morgan for something even less expensive than Deep Blue I suggested above. Squale would be another candidate, especially if one wants a Submariner look. Stepping up a notch above Deep blue, Sinn or Steinhardt. Next step up, UTS or Aquadive entry level watches. After that, Omega Seamaster and then a Sub. Above the Sub, I'd probably go VC Overseas, JLC Master Compressor or Breguet Marine. I'll give a nod to the PP Nautilus, but I really, really don't think he was asking for anything of that caliber. The crazy thing about watches is that if straight up durability and toughness under all conditions is what one must have, the best choices aren't usually the most expensive ones. The pricey ones will take a reasonable amount of beating, but if/when they break they aren't cheap to repair. Not so with the less expensive ones which in just about any situation will take just as much of a thrashing, sometimes more, before failing/breaking. All the best. Obris Morgan -- if you must wear a watch during lifting int he gym, I think the first OM pictured below will at least have a crown that won't press against your bent back wrist as you perform various exercises. UTS - various straps and bracelets are available Squale - lots of styles all reasonably priced.
Cheers,
12-17-2013, 02:15 AM | #21 |
301
Rep 1,591
$75 maybe? PM me if you're interested. Ill get you better pics
-JustinNApproved
12-17-2013, 10:00 AM | #22 |
483
Rep 1,389
Drives: F80 SO ZCP CCB
I have the all black Luminox and get plenty of compliments on it...esp from the ladies
A fisherman always sees another fisherman from afar
