E90 Alignment settings have changed after only 2 weeks
11-25-2013, 08:42 PM | #1 |
Rep 68
About 2 weeks ago I had new rubber put on my winter rims and since the car hasn't had an alignment in a while, I figured it would be a good time to. My steering wheel was also no longer centred to drive straight.
I got the alignment done, but forgot to ask for the print out. Anyway, drove off and later realized my steering wheel was still off centre. So I went back to fix it (now 2 weeks later) and had them give me a printout after they re-aligned the wheels. The first thing I noticed was how different the before & after were. So now I'm thinking - a) did they even perform an alignment the first time? or b) is my suspension shot to the point where it gets out of whack in 2 weeks. I've eliminated c) they entered non-sport suspension into the machine the first time, because the front left and right angle are very different. I've an E90 325i sport package. I had the car up on a hoist about 4 weeks ago, and there were no signs of leaky bushings. My front passenger strut had leaked a bit of fluid at one point. Not sure if the strut could cause misalignment and that 0.39 reading. Just wondering if the latest settings look accurate? And any ideas as to why the before and after are so different? Thanks
E90 2006 325i - 6MT - BSM
11-25-2013, 09:38 PM | #2 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
I've seen the same thing happen in my car. I think two things are happening:
1. The bolts that keep the steering rack fixed to the subframe have stretched/loosened. 2. The strut tower bolts have stretched/loosened. Do you have the alignment pins knocked out?
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
11-26-2013, 08:34 PM | #3 | |
146
Rep 1,160
They did a CRAP JOB the first time. Any alignment tech knows the steering wheel's centered when the job's complete. Zero thrust angle too. Hope you didn't pay twice! |
11-26-2013, 08:59 PM | #4 |
Rep 68
Sure didn't pay twice. Hope the alignment holds up though. I don't want to wear out the new tires
I'll check the alignment pin tomorrow, but I'm pretty sure it's still in Anyone have the official specs on e90 sport package to compare to? I've seen a couple different printouts from people EDIT: Alignment pins are in Last edited by magico; 11-27-2013 at 07:40 AM.. |
