upper control arm bolt keeps snapping?
11-23-2013, 03:20 AM | #1 |
Rep 98
2010 e92 335i m sport mt
ok so as the title says, my rear passenger side upper (front) control arm where is attaches to the knuckle. that bolt snapped a few weeks ago slamming into second gear. in turn the strut bent ,tire rubbed through the rainguard, torn boot from control arm rubbing on it. sooooo since i had to replace the strut i just did full coilovers (kw v1s) and i replaced the control arm (oem) and the hardware (also oem) as well as the boot….now today i slam into second gear and pop ..same bolt snapped again. wth can this be?! the car was in an accident in the rear prior to me and idk what they did when replacing what but the only logical thing i can think of is bad bushings but could that really cause that much torque to hit that bolt so specifically ? also theres like 9 fing bushings down there ! anyone hae a clue onto which one to replace? any thought would be greatly appreciated, really bummed out |
11-23-2013, 10:04 AM | #2 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
How bad was the accident? Sounds like something is really out of alignment between the front transmission and the rear differential. When you slam into 2nd there is a large shock introduced into the drivetrain which causes it to flex in the bushings, which if off could cause a failure.
My 2 cents |
11-23-2013, 10:48 AM | #3 | |
Rep 98
11-26-2013, 09:07 AM | #4 | |
146
Rep 1,160
Poss subframe distortion - you're prob seeing why it was for sale. You may be able to claim to one or the other's insurance if you can locate parties involved. Post result if you do! |
