BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > help with adjusting settings
      10-25-2007, 02:43 AM   #1
nublet
Drives: 325i
when i scroll through all the settings via the center stalk, I dont see the key with the check mark (for things like pathway lighting, daytime running lights, etc)
does anyone know why this isn't showing up? sorry if this is a n00b question.
      10-25-2007, 05:15 AM   #2
yatesey
yatesey's Avatar
Drives: 320 SE cab
Smile
have you got pro satnav? w idrive?.....the daylight settings etc are through the idrive.
cheers
"sex on legs!...well.. wheels!!..."
      10-25-2007, 07:31 AM   #3
gloster
15
Drives: 335i MT, sport
Because BMW is paranoid and won't let you set some options while moving.
I'm guessing you are in gear. Many options don't show up when you are in gear. Put your car in full accessory power mode (2 hits of the start button without foot on brake/clutch) and then try it.
      10-25-2007, 07:41 AM   #4
LEDZEP
LEDZEP's Avatar
417
Drives: 2009 E70 & 2011 F25
+1 This is most likely the problem.
I think it is bad luck to be superstitious
      10-25-2007, 08:10 AM   #5
nublet
Drives: 325i
no idrive. i'm parked and in accessory power mode
      10-25-2007, 08:57 AM   #6
Gort
Klaatu Barada Nikto
Gort's Avatar
No_Country
28
Drives: 2017 X3-35i
Have you pushed the button on the stalk, then toggled the lever on the stalk? The setting you are looking for should be the 9th "toggle". I'm sure you must have read the manual on this (starting pg. 58)? Good luck.
      10-25-2007, 10:28 AM   #7
gloster
15
OK, just as a sanity check, try this:
1) Put the car in Park on an automatic or Neutral + Emergency Brake with the a manual
2) Start the car (engine running). Leave it in Park/Neutral.
3) Look for the option
      10-25-2007, 11:06 AM   #8
HyperM3
Too many Alex's, from now on, call me Beaufort
342
Drives: See Sig
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip
16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone)
07 335i(gone)
      10-25-2007, 02:43 PM   #9
ChadS
Drives: '06 330i
What is the build date of your car? Pre 9/05 built cars don't have this capability.
      10-25-2007, 03:57 PM   #10
nublet
Drives: 325i
ahh thanks chad. my car was built 07/05.
      04-22-2010, 09:36 PM   #11
RealRadRyan
Drives: 2006, 330i
Does anyone know if this settings menu can be enabled on the pre-9/05 models?
Is there no way to update the software?
