Salt Marks on Carpet
12-12-2005, 04:15 PM | #1 |
82
Rep 5,732
I have tried just about everything but everytime I still end up just brushing it off as much as I can:
Is there a good product/trick to get salt stains off the carpet once they are on it and dry ? |
12-12-2005, 04:21 PM | #2 |
52
Rep 1,024
On the floor mats or the carpet itself? Have you tried a carpet cleaner (like one of those bissell machines). You might try letting it soak for a bit in warm soapy water first, could help the stain come up easier. Just a couple ideas. Hope it helps.
12-12-2005, 04:23 PM | #3 |
Enthusiast
466
Rep 1,791
Drives: F87 M2 / F31 330d
Garage List 2004 E46 BMW M3 [0.00]
2017 F87 BMW M2 [10.00] 2013 F31 330d Touring [9.50] 2009 E89 Z4 Sdrive 30i [9.00] 1989 E30 320is 2-door [10.00] 1986 E28 M535i [9.00] |
Seriously, I use a few sprays of brake cleaner on my velour mattes. Rub gently with a dry towel, it will remove any kinds of stains (even oil and chewing gum) and didnīt do any harm to the mattes.
12-12-2005, 04:23 PM | #4 |
82
Rep 5,732
Yeah, its on the carpet itslef on my wife's BMW - she cares a little less than me about these things
It is on the left sidewall just before the accelerator pedal, so soaking is hard to do unless I flood the car I have tried using soaked towels etc., with limited effect. |
12-12-2005, 04:58 PM | #5 |
30
Rep 278
Those salt marks are most likely calcium salt, organic solvent (brake or carb cleaner) will not able to remove them. You need water (best is very warm water). Use a shop vac and pour some warm water over it, do this for a few time, the salt will be gone. Vacumn it dry. HTH.
01-04-2006, 01:04 PM | #8 | |
Rep 74
I went to Canadian Tire and you can get black automotive carpet there, its about $20 for a decent size roll. I cut some pieces of that to fit under my rubber mats (rubber mats are a must in the winter), and these pieces are big enough to basically cover all the exposed carpet around my mats. The black that it comes in is just a little darker than the carpets in the car, it doesn't look too bad overall. So hopefully they'll contain the salt and I'll have nice plush carpets in the spring. -Tim |
