Injector Problem?? Codes Inside - Please Take A Look
11-21-2013, 09:51 PM | #1 |
152
Rep 2,638
Hi All,
Drove the car fine to work today. Turn it on to go home in the evening and it was driving like my dads 1970's diesel mercedes. I roughed it home through traffic. I just ran the codes and got the following: 2D06,1,Air-mass system 2A82,8,VANOS intake 2A98,1,Crankshaft-inlet camshaft, correlation 29CF,2,Combustion misfires, cylinder 3 29D9,2,Misfire at low tank fill level Anyways, would like to get it up and running this weekend. I'd appreciate your feedback. Last edited by mapleridge; 11-21-2013 at 09:58 PM.. |
11-22-2013, 10:40 AM | #3 | |
just another bmw douche bag
195
Rep 3,640
for the first code, I'd try removing and cleaning your MAF sensor, and see if that helps. the 2nd and 3rd codes are more serious though. could be that one triggers the other, but I don't know. search for a DIY on cleaning out the Vanos solenoids. |
11-22-2013, 01:05 PM | #4 |
152
Rep 2,638
I switched the coil from cylinder 3 to 1 and I got a misfire in both cylinders. I am thinking it is a bad coil and injector in cylinder 3.
I will clean the MAF. I was just going to change the intake vanos solenoid. What do you think? around 60K miles. |
11-25-2013, 10:19 AM | #5 |
708
Rep 2,606
Drives: 06 330i E90, 18 530xe G30
It is worth trying to clean and swap the solenoids(same part number for intake and exhaust) first to see if that makes a change. Just spray some maf cleaner and blow it dry with a compressed air nozzle.
11-28-2013, 12:59 AM | #6 |
152
Rep 2,638
I took it into the dealer because I thought it was the coil and injector from the little tests I ran. They replaced the coil under CPO and it is back to normal. I bought the gaskets for the solenoids and I will pull those out and clean them just as a precaution.
11-28-2013, 03:20 PM | #7 | |
708
Rep 2,606
12-04-2013, 04:01 PM | #8 |
24
Rep 254
Drives: 2022 G30 M Sport
where the MAF and how do you clean them?
