Comfort access unlocking
11-19-2013, 06:10 PM | #1 |
91
Rep 817
My car has the comfort access but the unlock feature where you touch the door handle works maybe one out of every 5 times that I try. Got a new battery for my key fob and that didn't help. I don't think it's a fuse since it does work occasionally. Any ideas why this is happening and how to fix? The lock feature where you touch the top of the handle works fine by the way.....
12-28-2013, 06:45 PM | #2 |
11
Rep 172
Are you touching the inside of the handle?
2011 E93 335is / BSM / Coral Red / 6MT / NAV / HK L7 / BSW Stage One / SWS8's
1994 E32 740iL / Black / Black 2008 E85 Z4 / Stratus Grey / Dream Red *SOLD* / 2006 E90 325i / Jet Black / Black *SOLD* / 2001 E53 X5 / Silver / Grey *SOLD* |
12-28-2013, 06:52 PM | #3 |
1915
Rep 13,107
The car battery itself could be weak .
I have noticed on mine its sometimes necessary to have the fob at shirt pocket level, or at least above the window level. |
12-30-2013, 02:21 AM | #4 |
558
Rep 406
mine just recently started doing this too.. haven't done the key fob battery replacement yet... but i also noticed everything inside the car has been resetted... (date and time... trip etc... i probably need a new battery i can only assume)
Instagram @luongspec
12-30-2013, 05:58 PM | #6 |
91
Rep 817
I just kind of figured something out on this. If I lock the car, and then try the comfort access by putting my hand on the handle, it works every time without fail and unlocks the car for up to about 2-3 minutes after i've locked the car. But, if i wait more than 2-3 minutes, it never works. It's almost like it's on a timer or something and won't work after a specified amount of time but always works for a short time after I've locked it......I wouldn't be surprised if there was some obscure timer setting for this but i have no idea how to change it or if there even is one.......
01-02-2014, 12:43 AM | #7 | |
295
Rep 2,202
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
01-04-2014, 04:23 PM | #8 |
91
Rep 817
Well I already changed the key fob battery and everything else seems to work fine. I guess I could get my battery checked out but I don't think anything is wrong with it....
01-04-2014, 05:28 PM | #9 | |
59
Rep 661
01-04-2014, 06:12 PM | #10 |
1915
Rep 13,107
If you have an 07 or 06 and it the original
If you have an 07 or 06 and it the original(car battery not fob)
You are due for a battery. 6 years is about the average maximum life of a battery in these car they are noted battery hogs. There is a glass eye on the battery that tells its condition but I would go by voltage measurements first. a healthy battery should be 12.6 if its 12 or under in the morning you better start looking for a battery or be stranded somewhere unless you have a manual you can push start. Also if the fob is in your pants pocket under the level of the window it won't work as well. |
01-15-2014, 09:19 AM | #11 | |
28
Rep 743
03-21-2015, 10:09 PM | #12 |
91
Rep 817
I finally got a new battery....my original lasted almost exactly 8 years! Comfort access unlock now works fine so my problem this whole time was due to a less than optimal battery......
03-22-2015, 08:45 AM | #13 | |
28
Rep 743
what were your symptoms prior to new battery? Thanks |
03-22-2015, 11:50 PM | #14 |
91
Rep 817
I didn't really have any other symptoms besides comfort access not working right. I don't drive my car all the time so I used a battery tender a lot. I've heard though that if your battery is not in good shape, it won't trigger the water pump to keep circulating coolant to the turbos after you shut off your car. I couldn't really tell if my old battery was or was not doing this.....
03-23-2015, 02:09 AM | #16 | |
522
Rep 1,527
