E92 M3 rear subframe will it fit E92 335i?
11-18-2013, 08:19 AM | #1 |
Rep 29
Hi there, need some advice, i planned to fit a complete e92 m3 rear subframe with LSD to my 335i next summer, but ive come into problems with the 335i subframe, looks like the bushes have gone, what id like to know is can fit the m3 e92 subframe on as these have better bushes and will my 335i diff fit in for now to get me out of trouble ?? ive got adjustable rear toe arms for m3 subframe too.
11-18-2013, 08:49 AM | #2 |
Rep 180
Drives: BMW E90 M3 ZCP
If you get the complete M3 subframe with arms, diff, brakes and dampers pretty much all you have to do is a custom driveshaft. If you source just the frame with diff you will need more custom work.
11-18-2013, 09:56 AM | #3 |
Rep 29
Yeh i know this mate, i just need to know if i can fit the 335i diff into the M3 subframe
11-18-2013, 10:57 AM | #4 | |
Rep 180
My bet is that it is the same and the diff will fit, but I am not 100%. Good luck though! Edit: checked realoem and it is not the same, sorry. If the diff fits, I do not know. Last edited by johmei; 11-18-2013 at 11:04 AM.. |
11-18-2013, 12:42 PM | #5 |
41
Rep 642
Looking at different sites that sell LSD, it sure doesn't look like the M3 differential and non-M3 are interchangeable. No idea why, but you can probably email the shops that sells them or the (aftermarket) manufacturer and get the reason.
It might be as simple as just having to change the drive shaft/halfshafts along with it. And the p/n difference between the m3/non-m3 sub-frame could be just some minor difference to accommodate slightly different attaching parts or whatever. Doesn't mean it won't work. I changed my 325i knuckle to a 335i. Different p/n's between the two, but it worked fine so long as you change out the half-shafts, bearing, hub, parking brake, calipers and rotors along with it. |
