Safe to clean rotors?
11-17-2013, 03:57 PM | #1 |
Bayerische Motoren Werke
23
Rep 251
Drives: recklessly
I have new Carbon brake pads coming in on Friday and while washing my car yesterday I noticed a very thin layer of rust is starting to build on the rotor. When I go to change the pads, is it safe to clean the rust with Brake Cleaner and a wire brush? If not, what IS the safest way to clean them?
Thanks! |
11-22-2013, 10:24 AM | #2 |
23
Rep 251
Drives: recklessly
Can anyone give any insight?
11-22-2013, 10:52 AM | #3 |
just another bmw douche bag
195
Rep 3,640
do you mean rust on the braking surface, or rust on the hub?
if it's on the hub, you can take them off, wirebrush them, and paint them. if it's on the braking surface, the pads will just scrape it off, no need to worry. some surface rust on the rotor is normal otherwise. |
11-22-2013, 10:53 AM | #4 | |
23
Rep 251
Drives: recklessly
Thanks for the info! |
11-22-2013, 11:56 AM | #5 |
252
Rep 1,157
you can clean the rust on the braking surface by applying the brakes!
but seriously, you can scuff the braking surface with scotchbrite or sandpaper to smooth it out and get all the bedding material off. then go and do a proper bed-in with your new pads. just be careful if you have zinc coated rotors.... if you remove the coating from the edges and hat of the disc it will begin to corrode there. |
11-22-2013, 11:58 AM | #6 | |
23
Rep 251
Drives: recklessly
11-22-2013, 03:40 PM | #7 |
Gateropode
329
Rep 2,848
No need to clean the rotor from rust, they'll clean themselves the first time you use the brakes.
If your new pad compound is different, you may want to scrub the rotors with emery paper and brake cleaner, to remove the old compound. Do not use sand/silica based paper, use only metallic based paper. |
11-23-2013, 12:59 PM | #8 |
23
Rep 251
Drives: recklessly
Replaced all the pads today. Everything is clean and working great, with exception to hubs which are a bit rusted but not enough to cause me concern. I'm very happy with the Cool Carbon pads. I'll get to the hubs at some point.
