M3 Suspension Conversion Qs
11-16-2013, 08:31 PM | #1 |
287
Rep 1,710
So I was talking with another enthusiast a few weeks ago about suspension setups and brands when the question to came to my mind about a conversion. I know it can be done and I want to do it. After doing toe and thrust arms and other items, would M3-specific coilovers be needed as opposed to regular 3er coilover setups?? I would like to know so I can plan accordingly when the time comes.
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod |
11-17-2013, 05:42 AM | #2 | |
146
Rep 1,160
Required: Shocks matched to your springs. Spring rate important. Talk to HP Autowerks and/or Ground Control. I like Eibach's linear springs....nope, don't need BMW/M3 springs/shocks. Desperately need to replace stock non-M3 springs/shocks. |
11-17-2013, 05:52 AM | #3 |
146
Rep 1,160
Why do you want OETuning ECU? JB4 tunes most of the fastest E9x.
Also, tuning magnefies deficiencies, maybe most egregious being the stock e-diff. An engineering exercise calculated to drive you mad, you're much better off with a real limited slip differential. Wavetrac and Quaife are the most recommended solutions, Wavetrac being a California company and lower cost the the European Quaife. LSD as a first mechanical mod is highly recommended - you'll be pleasantly surprised. Don't use a strong rear sway without limited slip diff, or wheel hop will be your constant companion! |
11-17-2013, 06:35 AM | #4 | |
171
Rep 2,682
Whether you get M3 or 335i style coilovers depends on how far you go with your M3 conversion. I.e. are you also swapping hubs? If so, you will need M3 style front shocks. Are you also swapping the rear lower camber links? If so, you will need M3 style rear shocks. If you do neither, then 335i shocks will work fine with all other M3 conversions.
11-17-2013, 01:53 PM | #5 | |
287
Rep 1,710
11-17-2013, 01:54 PM | #6 | |
287
Rep 1,710
11-17-2013, 05:47 PM | #7 | |
164
Rep 2,556
How does a stiffer rear sway bar contribute to wheel hop? It will reduce rear end grip while cornering.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
