BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Oil for my 320d e90 2005 SE
      11-13-2013, 02:24 PM   #1
soton
Drives: e90 320d 2005
Hello, need to top up some oil and have found 2 bottles in my garage but not sure if they are okay to use.
First one is Castrol Magnatec OE 5w-40
And the other is xflow type LL01 5w 30
Can I use any of these? Only shop local is tesco so can I buy the one I need from there?
      11-13-2013, 02:27 PM   #2
dj219957
dj219957's Avatar
Drives: 2009 e90, cic idrive pro
ive been using brit oil from ebay. meets the spec and is very cheap. touch wood my engine is still working
http://www.ebay.co.uk/itm/BRIT-OIL-L...item2a2c3cbee6
      11-13-2013, 02:29 PM   #3
soton
I shall look at online oils when I service, but got the low oil message on way home so don't fancy waiting as I need to do it ASAP!
      11-13-2013, 02:29 PM   #4
dj219957
dj219957's Avatar
from memory ll01 is ok but not preferred, so would be ok to top up. check your operators manual.
      11-13-2013, 04:34 PM   #5
Alex.J
Alex.J's Avatar
56
Drives: BMW E92 335i MSport
I would either not bother topping it up and change the oil fully in a couple of days or top it up and change the oil anyway in a few more days!
      11-13-2013, 05:31 PM   #6
soton
Okay, think I'll grab a litre just out my mind at rest and buy the stuff needed for an oil change soon.
The only warning that came up was the notification triangle next to the mileage and in the check error messages on idrive it said oil level at low.
Is this just a prompt? So can be driven say 20 miles to work etc?
      11-13-2013, 05:53 PM   #7
Alex.J
Alex.J's Avatar
56
Yeah thats fine! Its not ideal to be at low on the dipstick but not the worst!
If you had low oil pressure, i would be concerned!
Give it a litre and get it changed, then check it more often!
      11-14-2013, 02:02 AM   #8
Jase 320d
Wheelbarrow Edition
Jase 320d's Avatar
Scotland
60
Drives: Arctic 320d
The wrong oil is better than no oil
Aslong as its a temporary measure until a full change can be done with correct oil
      11-14-2013, 06:17 AM   #9
Icekube
Scotland
46
Drives: E87 130i
as above, oil is oil, either of thouse will be fine for a top up.
when changing oil, don't bother wasting money paying extra for BMW spec oil either.
look for the industry standard of ACEA A3/B4, as that is all the LL04 spec means anyway, BMW don't have magicians making oil.... they buy it off the shelf like everyone else.
