E90 19x10 all around Mounted
11-12-2013, 11:55 AM | #1 |
Rep 8
Just thought I'd share for possible e90 owners looking to go 19x10 all around.
19x10 +32 offset 5mm spacer in front to clear No spacers in the rear (will be putting 25mm spacers soon, just need to roll/pull my fender as it will rub) 245/35/19 in front 275/35/19 in rear |
11-12-2013, 12:00 PM | #2 |
223
Rep 5,120
Looks good just needs a spacer in the rear to match the front. The front is actually an easy fit. Et7 with a 275 is going to take some work though good luck.
11-12-2013, 12:04 PM | #3 | |
Rep 8
I believe the spacer is actually a 20mm, but nonetheless I tried it on when I was mounting the rears, and it rubbed but not horribly. Some fender pull/roll and camber + alignment should do the trick and look aggressive. (hopefully, if not Ill get a smaller one like 15mm |
11-12-2013, 12:19 PM | #4 |
A family of bimmers
2748
Rep 7,742
lets see a shot from the front to see how much the front really pokes. its easy to hide it from the angles you posted.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
11-13-2013, 01:56 PM | #8 |
79
Rep 2,110
I like were this is going! More pics!
You'd be way better off just trimming the rear fender lip off, rolling and pulling(bad idea) aren't going to get you much due to the way the rear fenders lips on e90's are made. trim it, sand it smooth, seal it, done. |
