2010 2011 BMW 5 Series Forum F10 Snow Tires for F10 535i xDrive |
11-11-2013, 09:21 AM | #1 |
Rep 30
Shopping for snow tires for my 2013 535i xDrive (non M-Sport)
Stock size is: 245/45R18 Any recommendations? Thanks! |
11-12-2013, 05:38 AM | #2 |
256
Rep 4,721
Michelin PA4
Bridgestone LM60 (being discontinued but still selling) or LM32 (new) Dunlop WS 4D In toronto, you can check out Simply Tires, Joy City. Reasonably priced shops. If you need wheels, check out BBS CH-R, approx. $3300 a set, if you have the budget for them. Otherwise, replicas would be okay but the quality is hit & miss. |
11-12-2013, 08:58 AM | #3 |
Rep 30
Does anyone know the 18" wheel size for 535i (non-sport)? Is this correct?
Tire: 245/45 R18 Rim: 8 x 18 Offset: ET30 or ET35? Bolt pattern: 5 x 120 Center bore: 72.6 Thread size: M14 x 1.25 ? |
11-12-2013, 08:18 PM | #6 |
256
Rep 4,721
11-12-2013, 08:48 PM | #7 | |
Rep 30
http://www.rtxwheels.com/en/content/berlin-bmw http://drift-wheel.en.hisupplier.com...WHEEL-RIM.html |
11-13-2013, 06:23 AM | #8 |
256
Rep 4,721
Just make sure you run on the highway after install, the objective is to make sure there is no vibration even though it says they are hub centric, only the stock oem wheels are TRULY of that. If you have issue, then go back to the shop and ask for Road Force balancing as to reduce (not eliminate) the vibration issue.
