4X4 ABS light has come on, chassis malfunction? What's going on?
11-08-2013, 10:33 PM | #1 |
Boooost!
70
Rep 793
Drives: 335i
I was coding my windows to close with fobb and I got a 4x4 chassis malfunction error but no codes.
Is this related? I am confused why this would happen. I also had the fobb in with the car off but I turned interior lights off so I wouldn't drain battery. I have done this a few times over the last couple of days but no errors until tonight. I was using NCS dummy and trying to write something from the read nettodata and updated module. I the only values I have touched are the FSW PSW MAN file and lights only. I reinstalled all the programs from scratch and then re-uploaded my backup of the FSW PSW man file. Just wanted to see what you guys think about this. I did flash the TCU with the Alpina program with the latest Daten 50.2. I haven't had a single issue since I did it and it was three days ago. Edit: I checked the error id and it says "CC-ID683". The magic eye on the battery isn't green or yellow it's just clear and dark hole I assume black?
JB4 Stage 2 | Injen CAI | BMW PE | AR Catless DP | Alpina TCU Flash | Eibach Pro Kit | Custom TCKline Koni's | 19" M359 Wheels | DWS Tires |
11-09-2013, 08:42 AM | #2 |
65
Rep 1,274
One of your sensors in your wheels are either damaged or it's dirty! Get the car on the lift and check all 4 sensors inside the wheels and you ll see what's going on. I had the same problem.
11-09-2013, 03:09 PM | #3 | |
Boooost!
70
Rep 793
Drives: 335i
11-09-2013, 06:01 PM | #4 |
Boooost!
70
Rep 793
Drives: 335i
The magic eye on my battery won't turn green. Been on a 12v charger for 45 minutes.
After 2 quick charges I removed the batter which was about 2 hours. If I tilt the battery back and forth I can see the green eye highlight and then it rolls past and it's black again. Car starts up no problem and I have 13.7 volts with the car unplugged.
11-09-2013, 08:10 PM | #5 |
Boooost!
70
Rep 793
Drives: 335i
I opened inpa and went to select chassis and then dsc dcx and then I did a program re calibrate and I heard a click below my feet and I could feel it.
Lights all off.
