10-30-2013, 02:47 PM | #1 |
20
Rep 166
JB4 stage 2 map 7 as a daily driver?
I plan on running my 2014 335xi with a JB4 stage 2 map 7 E85/93 50/50 as a daily driver. I'll be running a cat less DP, full exhaust and an intake. Is anyone else running map 7 50/50 as a daily driver? I have E85 at every gas station near my house so that's no biggie. Would I see any issues with the car?
10-30-2013, 02:50 PM | #2 |
195
Rep 467
You'll be fine but I opted for Map 2 to keep undue stress on the snail shell turbo. That little thing has to work like crazy to keep up with Map 7. I'm anxiously awaiting dash control map switching on the F30.
2011 335is Black/Oyster. 1 of 46 without moonroof (total of all years): JB4 E50 tune, gone
2013 335i M Sport JB4: Estoril Blue gone 2018 M4 ZCP: current 2023 X3M Comp: current |
10-30-2013, 08:16 PM | #4 |
BimmerPost Supporting Vendor
24312
Rep 191,025
It is a matter of preference. Map 7 is still a very safe map, but you probably are better off with a less aggressive map as a daily driver. Im running a custom map with 20psi on stock turbos so im probably not the right person to ask
10-31-2013, 08:30 AM | #7 |
20
Rep 166
The E85 handles most of the cooling. Burger tuning said I don't even need the aftermarket intercooler due to the E85 burning so cool.
10-31-2013, 08:31 AM | #8 |
20
Rep 166
10-31-2013, 09:17 AM | #9 |
107
Rep 1,997
10-31-2013, 09:19 AM | #10 |
155
Rep 1,400
If Terry told you that then that is the advice I would follow. I know from my driving style and logs that I could use meth and or intercooler, specially for the summer months. That's one of the biggest advantages of meth it will keep your IAT down because your car will pull timing and boost. My car is much slower in the summer time without it.
11-01-2013, 07:12 AM | #11 |
24312
Rep 191,025
I would think no matter what our FMIC needs to be upgraded, but if terry said you don't need to change it, then you don't He knows what he is talking about.
11-01-2013, 08:24 AM | #12 |
20
Rep 166
I'm beginning to wonder how I worded my question to Terry, I'll have to ask him again once the weather warms up.
11-01-2013, 08:25 AM | #13 |
24312
Rep 191,025
Good idea
11-05-2013, 04:23 PM | #14 |
210
Rep 1,252
i'm new to JB4 stage 2 came from MPPK i feel more torque but im not sure when to shift at 2nd gear (6.5k?)
3rd/4th ?? any tips ?
Docrace 6266
11-05-2013, 07:13 PM | #15 |
195
Rep 467
5,800
Chicken_Joe606.00 |
11-06-2013, 07:01 AM | #16 |
210
Rep 1,252
aww Q_Q i used to shift at 7.050 when i had MPPK
i love high revving engines , i guess ill have to switch to map0 when i wanna rev it high ;p
Docrace 6266
11-06-2013, 09:05 AM | #17 | |
107
Rep 1,997
I don't think the torque curve changes much between two, just the area under the curve, i.e., jb4 will make more power at a given RPM for the most part. That said, yea these engines/turbo combos lose steam at higher RPM. There is a calculator out there somewhere that allows you to input the torque curve and it tells you the optimum shift points. If I recall correctly in first (to second) and 2nd (to third) it's at redline and third (to 4th) around 6500. I read about why and forget the details but what I got out of it was the first two shifts should be near redline with the next coming a few hundred RPM shorter due to gearing and the potential for less shifts. Note this is for maximum acceleration not maximum hp at all times, which is counterproductive in the lower gears when trying for maximum acceleration. Kinda not what you'd expect but apparently short shifting isn't the way to go until you are in 3rd and above. |
11-06-2013, 09:45 PM | #19 | |
195
Rep 467
Although, I agree with you a little more because of our flat torque curve. On a non-turbo engine with a Big torque peak, my old school rational makes more sense : )
10-22-2015, 10:45 AM | #20 | |
21
Rep 166
Bringing this post back from the dead, how did you go about getting a custom map done, I have some dyno time coming up and wanted to fine tune the JB4 as much as possible.
M Sport: ~JB4 STG 2 ~ FF Wires ~ AFE 5R Intake - Catless ER DP ~Tints ~ CF Interior Trim ~ CF Diffuser ~ CF Trunk Spoiler ~ CF Mirrors
10-22-2015, 12:22 PM | #21 |
24312
Rep 191,025
I did it myself using map 6.
Dereli80.50 |
10-23-2015, 10:31 AM | #22 |
4920
Rep 115,999
