Strange Electrical Problem
10-28-2013, 04:23 PM | #1 |
Rep 122
So on my way to work today, I started losing power. First ABS/Stability Control/4x4 error. As I was pulling over, Airbag error. Tried to cycle ignition and car wouldn't start. Used a booster pack to get the car to a gas station where they hooked it up to a charger for half an hr. The gauge on the charger showed OK. Still didn't start. Had the car towed to my Indy. Battery is about 1 yr old. Alternator is original (06 330xi with about 108k). All signs seemed to point to alternator. Indy tests electrical system after fully charging battery and everything is functioning fine. Any ideas what may be causing this?? Any usual grounds or bad connection points on the vehicle?
~Sari |
10-28-2013, 06:39 PM | #2 | |
223
Rep 5,120
Or did the car start after the battery was charged? If so it sounds like the alternator is the problem like you suggested. |
10-28-2013, 07:09 PM | #3 |
Macgyver
208
Rep 942
Sounds like the alternator . When the rectifier is on its way out or gone, then it no longer is putting out DC . Rather AC is coming out and can wreak havoc on system designed to have a ground plane as reference voltage. So all the systems tend to trigger on the gauges as faults. Alternator problems tend to happen more at night when large loads are incurred by headlights , air conditioning / heater, radio etc is all on. During the day it may seem the symptoms are not as bad. Best of luck with it!
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
10-28-2013, 08:02 PM | #4 |
Rep 122
The Indy Shop tested the system with a 100A load and said the Alternator was behaving as it should. Is it typical for these vehicles to have some kind of an intermittent alternator failure?
10-28-2013, 08:42 PM | #6 | |
Macgyver
208
Rep 942
