TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Had some issues with our 330xi last week
      10-26-2013, 07:51 AM   #1
weareweird69
88
Drives: 2014 X5 35d
I know I don't post much. But I'm posting for others to learn or to help diagnose their car.
We got our oil changed in our 06 330xi well. After that it developed a very rough idle.
Throwing 2EF4. 29CD. 29D0. 29CC. 2A2F. 2A2E
Now. These in order are Map sensor. Misfire Injectors 1 + 4. Multiple injectors misfire. And A/F codes
It would run fine. But off idle or at idle would run like pure crap.
After looking around online and diagnosing the car. I saw one person say to check the oil cap.
After inspecting that. It was a 1/4 turn lose. It caught the engine cover. After tightening. The engine ran fine
Yesterday. The car wouldn't start. 12 volts at the battery. All the lights worked. Over the past two months. The HVAC fan wouldn't run at full speed. Well. When you hit the start button. The car would blink off. Then back on. at this time the battery dropped to 7-8 volts. Then back to 12.
Battery indicator just stated it was low on charge. But that doesn't explain the retarded voltage drop.
Not to mention its been getting slower to start in the mornings.
I replaced the battery. No I didn't have it registered. I may do that. Depending on cost but non ill effects. I purchased an AGM battery from advance auto. I got a good discount on it. Anyway. Their computers called for an H6 battery. But that wasn't right and the guy knew it. He said it was really an H8. So he got that and it was a perfect fit. And was 900CCA! So the battery fixed all the other issues as well.
Just posted this here for all to see. And maybe help them with their cars
      10-26-2013, 11:51 PM   #2
E90-Phoenix
Drives: E90 soon!
A loose oil cap and a bad battery did all that...glad it's resolved and for very little $$$
Thanks for sharing.
      10-27-2013, 12:40 AM   #3
BMW_TECH
Drives: 2010 335d
Thanks for sharing.
A loose oil cap can definitely cause those problems. Any vacuum leak will cause the car to lean out to the point of misfires.
Without the battery registration and correct coding for AGM battery you run the risk of killing your new battery prematurely. Up to you whether you think the added cost of the coding/registration is worth it or not...
      10-27-2013, 04:26 AM   #4
mike3000fl
No_Country
138
Drives: 06 330i
i bought a battery at walmart 3 years ago. never registered and car is happy still
      02-02-2014, 03:27 PM   #5
weareweird69
88
Drives: 2014 X5 35d
Holy thread revival lol
No issues with the new battery yet.
I can't see spending the 100 bucks and 30-45 minute drive to have it registered. I can get a new battery for the same cost and have a new battery. Lol
And that's why I shared. So others who may have those issues can check those first!
