picked up german import 335i some questions
10-20-2013, 08:16 AM | #1 |
30
Rep 373
Pretty neat! But I am wondering the differneces between the american vs german 335i with xdrive.
I noticed the maps are all german from 2008, can I upgrade that? I read I might have to upgrade idrive, then maps? Do I have CCC or CIC? Do I need to get the FSC code and can I update via USB? One problem I noticed, the cars climate control is a little odd, the vents that blow directly to the people only blows HOT if you sleect 84F, otherwise at 83F its pretty cold. Is there any way to add factory BT to the car still? It has navi + idrive, so hopefully not too hard? Is it possible to do a carfax similar service of a car from germany? Can I tell how big the hard drive is in the car? Can I wipe the old music on here and add just new? Is there specific formats the files must be in? Thanks guys, you've all been very helpeful! |
10-20-2013, 08:31 PM | #4 |
Rep 60
Turn the red/blue dial in between the 2 center vents to red.
Took me a while to figure this out to, just got cold enough down here this weekend to use heat. |
10-20-2013, 08:48 PM | #5 |
Where'd my VTEC go?
481
Rep 6,067
How do you have a german import?
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
10-20-2013, 09:56 PM | #8 |
I have to return some video tapes
362
Rep 4,712
+1
well actually the SUVs and z4 are made in the US. actually I don't know if they still make the z4 here.
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
10-20-2013, 10:03 PM | #9 |
930
Rep 5,538
10-20-2013, 10:27 PM | #10 |
Where'd my VTEC go?
481
Rep 6,067
Ok yes, but I'm assuming he meant he somehow has a car built for the German market and not originally intended for use in the US.
10-20-2013, 10:44 PM | #11 |
291
Rep 2,189
I think he created two posts about the same thing.
There's another post where he says that there's a large gap in the carfax and he found out it was shipped over from Germany around 50K miles. |
10-21-2013, 07:22 AM | #12 |
930
Rep 5,538
10-21-2013, 07:25 AM | #13 | |
930
Rep 5,538
At least thats how it works on the export side from US......beautiful salvage cars exported to other countries. Good business too |
10-21-2013, 09:49 AM | #15 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
10-21-2013, 09:51 AM | #16 |
110
Rep 2,017
Since it's an 08, you just got to get a North American Map disk. It'll work fine. When I did EuroDelivery on mine, I just popped in a Euro map disk when I was there. It still had some of the Germany address entries when I got it back in US under the history of destinatinos even with the North American map disk.
10-21-2013, 09:55 AM | #17 | |
110
Rep 2,017
Are you sure your car wasn't a US bound EuroDelivery car? |
10-21-2013, 10:14 AM | #18 | |
Where'd my VTEC go?
481
Rep 6,067
10-21-2013, 11:09 AM | #20 | |||
30
Rep 373
What's RHD? I also don't have a seperate DVD drive, only one CD drive spot. I also see some songs were preloaded so I deleted the crap ones and will try uploading my own, that's why I was wondering what format. Quote:
haha, yeah I figured this out in my long drive home. |
10-21-2013, 12:00 PM | #21 |
110
Rep 2,017
Oh then you have an 09, I assumed that since your maps were 08, that you owned an 08. 09's have CIC navigation and you will need FSC codes to update maps. There is a guy on another forum that sells the FSC codes.
Your car is probably a USA spec car that was ordered under the military plan. |
10-21-2013, 12:07 PM | #22 |
Curmudgeon and Pedant
690
Rep 3,489
