Help with M steering wheel paddle compatibility!
10-17-2013, 09:47 AM | #1 |
Rep 57
M steering wheel question
I'm looking to get either an M3 or M-Tech steering wheel for my 09 335i w/sport package. But i need to know which paddles would be compatible to replace my push/pull paddles as I want the other setup(left -downshift & right -up shift)If anyone can provide me an avenue to plug n play paddles I can go to with a new steering wheel it would be appreciated!
10-17-2013, 12:08 PM | #2 |
508
Rep 2,981
Drives: 2013 BMW F30 EBII
Since you already have paddles, I believe you can just put the DCT paddles in without any further wiring or harnesses.
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread |
10-17-2013, 04:14 PM | #3 |
866
Rep 5,450
I just put in the DCT paddles on my 2008 and it was plug and play no issues, pull only right is up, left is down. At some point in 2011 or 12 BMW changed the paddles to not be a switch but have resistance in the circuit, so just be careful you don't get 2011 or newer paddles without finding the change over date as new ones won't work.
You can also modify the existing your existing paddles to just do up on the right and down on the left. Diagrams of paddle connector wire functions: Left Paddle Connector ______ 3-------|<--downshift (press) 2-------|<--ground 1-------|<--upshift (squeeze) ==<-tab Right Paddle Connector ==<-tab 1-------|<--downshift (press) 2-------|<--ground 3-------|<--upshift (squeeze) _____| The left and right connector pin numbers have different functions because the connectors are flipped from left to right. The numbers are small but visible, pin 1 is always next to the tab as shown. 5) Remove the pin 1 wire and pin from each connector by unclamping the small connector hinged piece and pressing the exposed pin release tab. Do not remove the pin 2 and pin 3 wires. 6) Connect the pin 1 wire to the pin 3 wire on each paddle. This gives left downshift only and right upshift only on both movements of the shifters. I cut off the pin and spliced the wires using solder with heat shrink tubing for insulation. Other connection schemes may be devised, don't forget to insulate well. 7) Reconnect and reassemble everything, then try it out.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
