Audio conversation questions
10-12-2013, 01:36 AM | #1 |
Rep 44
I have an 06 325i with the head unit built into the top of the dash instead of the middle.. Unfortunately it went out. I can't seem to figure out what's causing it. I unplugged the 30 amp fuse an then it'll turn on for about two minutes then blacks out. Any ideas of what this could be that causes that? I was told the rear amplifier on the left side or then main ccc unit. I was thinking to possibly stick an aftermarket unit in if that's possible.. Which I'm thinking it's probably not going to work due to the location of the screen. Please help, going crazy trying to solve this issue.
Cheers Nick |
10-13-2013, 01:22 AM | #4 |
1918
Rep 13,115
Well have you made in progress?
Did you check the battery ? I don't believe I have seen anybody on here retrofit and I drive car with and aftermarket stereo . Doesn't mean it hasn't been done. Trouble with and aftermarket head unit in these is there are a lot of things attached to it and when you pull it those things stop working . Things such as BMW Sos , PDC , Bluetooth and cdc. Plus if you ever have to go to a dealer the BMW diag computer won't work with the car unless it sees the original configuration of the car with the Radio and all the options that were initially installed. It is possible to enhance the sound quality though. |
10-16-2013, 01:04 PM | #5 | |
Rep 44
Cheers Nick |
