Should I be putting premium gas in my 325I?
10-16-2007, 02:56 PM | #2 |
539
Rep 18,123
About 10 cents per 2 octane. Don't be cheap.
Current: 2010 Alpine White 335D LCI l 19" BBS LMs l KW V2 Coilovers l BMW Performance Grilles l MSport Front/Rear l Karbonwerke Trunk l F1 Pinnacle Tint 35% Former: E92 Space Grey 335i Latest pics |
10-16-2007, 03:13 PM | #5 |
98
Rep 3,618
Put in premium. Whatever you think you'll save in the cost per litre/gallon between 87 and 91, you'll end up losing more in poorer fuel economy.
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone 2010 Mercedes-Benz C350 4Matic - Gone 2006 BMW 330xi - Gone 2001 Infiniti QX4 - Gone |
10-16-2007, 03:20 PM | #6 |
198
Rep 2,485
Use what is recommended.
It doesn't say 'Premium' in the owners manual just to piss you off. A higher octane represents a higher resistance to detonation. If you use a lower octane gasoline in an engine designed for premium, the ECM will retard the timing and you performance and economy will suffer. Conversely, there is generally no advantage to putting premium in an engine designed for regular. You may (or may not) get some additives that aren't in regular but you won't be going any quicker unless you play with the ECM.
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
10-16-2007, 03:23 PM | #8 |
Rep 109
Well ive always been putting premium, but i lend the car to my dad for 3 days and he put $10 worth of unleaded. After that he told me that he filled it up with premium when I found out. It was only one time...
10-16-2007, 04:10 PM | #10 |
Careful, I Bite.....
153
Rep 504
All gas is now unleaded. Putting $10 of regular gas into your car once shouldn't hurt it.
10-16-2007, 04:40 PM | #13 |
137
Rep 1,243
Lets just say if you ever have an engine issue and it goes to the dealer and they decide to test your gas and they find you are not using the recommended fuel bam your warranty is void. So if you really think its worth saving $2 every fill up then go for it, it might end up costing you in the long run if you have an issue.
10-16-2007, 04:46 PM | #14 | |
112
Rep 1,772
Your car is equipped with cylinder-specific knock control. This means that when you put in a gasoline with lower octane, the computer will retard the ignition timing to prevent knock. This means you will have less performance and WORSE FUEL MILEAGE. Long story made short --> Using Premium will cost you the same as using Regular gas due to better gas mileage from premium and your car will be much more enjoyable with premium gas. Also, the long term health of your engine will be better with premium. |
10-16-2007, 07:01 PM | #15 |
Rep 102
Lets see, we spend $38K+ on a car then a bunch more $$ on upgades and mods, and dont want to spend an extra $4.00 for a tank of gas...something doesnt add up
2007 335xi | Premium pkg |Cold Weather pkg| Comfort Acc | Logic 7 w/ iPod & USB|
1968 MG-B Roadster |
10-16-2007, 07:24 PM | #18 | |
1706
Rep 14,829
But, BMWs were designed for premium, so the simple answer is to use it. Someday everyone will be like the 2k8 CTS and deliver the 300+ HP while being designed for 87. |
10-16-2007, 07:48 PM | #19 | |
Rep 152
10-16-2007, 08:22 PM | #20 | |
Rep 160
10-16-2007, 08:24 PM | #21 | |
1706
Rep 14,829
The 328 is 87 and the 335 is 89 minimum. But it was designed for super, so there is a benefit to using super. If it were an '08 CTS with direct injection, the car was designed for 87 (beautiful), so there would be zero benefit to using 91 or 93. |
10-16-2007, 08:54 PM | #22 |
Rep 63
Do as I did. Test mpg for both regular and premium. Then choose a long straight hill and test for top speed at the top with both fuels. This will give you some indication as to what power gain or loss you have with each fuel. Then decide which fuel you should use. The results will save you money. BTW... regular is acceptable in a 325/328 and will NOT void your warranty.
