Need help with iPod/USB Adapter
10-13-2007, 07:52 PM | #1 |
18
Rep 171
I got the $400 option of iPod/USB Adapter when i ordered the car and i am confused how to use it. The dealer is closed 2m so i wanna try to solve the problem myself.
I just got the car so im not sure if the dealer was suppose to give me a wire or something. Where does the ipod connect. In the dash? or through the hand rest area? Also was i suppose to get a wire from the dealer? I tried hooking up the ipod through the white usb wire u get in the box when u buy an ipod and it didnt work, the car doest seem to be reading the ipod. I had it connected for over an hour with onli 2 songs in the ipod. I think i am connecting it wrong. I connected in usb and the aux. Shouldn't there be a simple wire that u just hook ur ipod too in the dash? Pictures would be very appreciated.. Last edited by whytboy; 10-13-2007 at 07:53 PM.. Reason: forgot something |
10-13-2007, 10:59 PM | #2 |
LA Native
14
Rep 294
Use your usb port in the center console to hook up your ipod using, the original ipod cable. When you drill down into entertainment, drill down, and select AUX. You maybe prompted to configure some tone volume so you actually need to go one level back up and under 'AUX' you will actually be given the option to select the jack, and whatever is plugged into the USB port. Your IPOD's name should be listed there. It took a little bit of time for me to figure out as well. Good luck.
10-13-2007, 11:01 PM | #3 | |
Rep 97
It should work.
:One of the first 335i in So Cal, Ordered 8/2006, got it 11/2006. Sports pkg, ipod intergration, clear bra, mrr design wheels/faulkens 452's.
