Is the Juicebox essentially the same as a Manual Boost Controller?
10-13-2007, 02:17 PM | #1 |
Checkraising with air....
Rep 66
It appears (to me, a layman) that the JB is just an electronic version of a
MBC.... I assume there is some sort of difference that I haven't considered? |
10-13-2007, 02:32 PM | #3 |
Rep 84
MBCs or EBCs control boost only. JB (and others) supposedly control timing and fuel as well. Going up more than a little in boost only, without managing timing and fuel could lead to problems. Depends on how much flexibility is in the OEM gear. It is very expensive to find out.
'08 E90 335i Sparkling Graphite PCD 11/28 |
10-13-2007, 02:35 PM | #4 | |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
10-13-2007, 02:40 PM | #5 |
1577
Rep 3,888
The JB2 goes to 11.5psi, about 3 psi over stock. The JB2 lets the stock map handle the timing and fuel for this up to a certain RPM. At that point, regardless of conditions, the JB2 makes the ECU think things are running lean, so ECU adds fuel.
10-13-2007, 05:06 PM | #6 |
Samtaro!
124
Rep 2,601
JB1 and SSTT increase boost only, allowing the stock ECU to make timing and fuel adjustments to compensate. JB2 adds an additional compensation for fuel, more than for which the stock ECU map is programmed.
10-13-2007, 05:14 PM | #7 |
1577
Rep 3,888
10-14-2007, 05:30 PM | #8 |
123
Rep 2,097
+1 it relies on the ECU to make adjustments.It basically tricks the car into thinking it's always in a High Altidude situation.Which is why I don't consider Terry a "Tuner".
10-14-2007, 05:54 PM | #9 |
296
Rep 1,515
Drives: Ever changing fleet
Wrong, there's absolutely no "high altitude" situation created by the JB, thats total BS. And every piggyback relies on the ECU to "make adjustments." If it were making all "adjustments" it wouldn't be a piggyback, it would be a standalone. The JB2 does not induce an offset on the crank trigger and influence timing directly like the xede, etc.
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
10-14-2007, 06:02 PM | #11 | |
123
Rep 2,097
10-14-2007, 06:46 PM | #12 |
Under the radar
41
Rep 840
10-14-2007, 07:00 PM | #14 |
grand poobah
254
Rep 2,253
I would say that the effect is similar to that of an MBC. In that in one way way or another it raises boost. It goes about doing it in a different way than an MBC does though.
If I understand correctly it is basically just a few resistors that makes the ECU think it is at a lower boost level than it really is. If 12psi of boost is normally 5 volts output this resistor bleeds off X volts to make it think it's only at 8 psi. What it doesn't do to my understanding (besides control ignition timing) is take RPM into account. It is just trying to turn up the boost and increase fuel by X amount regardless of what RPM the engine is turning. Which is like an MBC and not ideal. |
10-14-2007, 07:46 PM | #15 |
296
Rep 1,515
It obviously works as well as the ones with timing control, maybe even better since the consistency is there with considerably less boost.
10-16-2007, 01:50 PM | #17 |
Rep 310
The car has timing control, so why mess with that if not needed? None of the current choices are really "tuner" the piggy backs on other cars, allow everything to be controlled and tuned individually, which is not happening currently with the tuning for this engine.
10-16-2007, 07:04 PM | #18 | |
1577
Rep 3,888
So if you're running on the edge of the stock map, which means effectively using the safety margin, it's not a good thing - because now that margin is no longer available. |
10-16-2007, 07:13 PM | #19 |
90
Rep 300
10-16-2007, 07:34 PM | #20 | |
grand poobah
254
Rep 2,253
Most likely to prevent dumb asses who think they know what they are doing from screwing with the map then claiming "Brand X's piggy back blew my motor." As far as the "why mess with ignition timing argument" goes it's a simple answer because, that's part of how you make power. |
10-16-2007, 09:09 PM | #21 | |
25
Rep 752
Jeff Eurobahn |
10-16-2007, 09:50 PM | #22 |
296
Rep 1,515
Jeff, I find it odd that this is the case considering the connector, which no doubt is the TT strong point as far as install, contains no such circuit for intake air temperature data...making its modification dubious at best. Please provide us with a wiring diagram or some other modality of proof, if you don't mind.
