09-25-2013, 12:38 PM | #1 |
135
Rep 2,517
Drives: '11 335xi e92 M-Pak
Bi Turbo vs Twin Turbo?
Ok now that the new M3/M4 will have a "bi turbo".
What exactly is the difference? Is there a difference, since technically bi=two so 2=twin. Is one turbo for a first range of RPM and second is the the next range of RPM. This would be interesting comparison since BMW now has a car with a Twin Turbo (N54) and a car thats called Bi Turbo (S55). Tried searching around Google but nothing no satisfactory answer everyone seems to have some different opinions.
09-25-2013, 12:41 PM | #2 | |
Kaskasero
55
Rep 345
Rides:
BSM E53 X5 3.0i | Mods: 4.8is Style 168 wheels 1996 MB C280 Sport 2001 E39 M5 |
09-25-2013, 12:42 PM | #3 |
127
Rep 1,185
The term twin turbo has been often given to vehicles that use sequential turbos, a small one for low rpm torque, and a larger one for higher rpms and power. The biturbo system uses two equally sized turbos, one fed by cylinders 1-3, and the other by cylinders 4-6. They are not sequential or in series, but in parallel.
09-25-2013, 12:44 PM | #4 |
Ya ya ya, I am Lorde, ya ya!
266
Rep 2,772
Drives: E90 M3, 2015 SQ5
Really?? Already with these threads!?
09-25-2013, 12:56 PM | #5 |
1714
Rep 5,110
BMW uses the phrase "Twin Power Turbo" for marketing speak. Either referring to a twin scroll single turbo or two turbos (a bit confusing).
This has Twin Turbo, which just is two turbos (as seen in the photos). BiTurbo or Twin Turbo is basically two turbos. Sometimes in paralell, sometimes serial, but still two separate turbos. The exception being BMW's "Twin Power Turbo" which can be one or two turbos as explained above... |
09-25-2013, 01:06 PM | #6 | |
3487
Rep 9,709
Regarding the twin turbo / BiTurbo, both terms can be swapped as they mean the same. For me I would expect Twin to mean two the same(same size in the case of Turbo's), but this is not always the case. |
09-28-2013, 12:38 PM | #7 |
74
Rep 348
This thread seems silly but I could see there being a difference. If there was two separate turbo systems that handle 3 cylinders each, you could call that a (identical) twin turbo. If there is two serial turbos of different size on the same circuit, you would call that a bi-turbo.
