PROcede V2 wideband O2 and speed limiter support
10-12-2007, 04:15 PM | #1 |
Moderator
270
Rep 4,481
Hi Shiv,
I don't want to behave impatient, my question is only related to planning. - When do you plan to activate speed sensor functionality ? It can be used to defend the speed limiter as well. Can't we use the old green wire loom for speed limiter functionality ? - When will you start to support a standard 0-5V wideband O2 sensor ? I did the wiring today from the engine compartment to the cabin. What a PITA. I guess you will fine adjust AFR using this sensor, dedicated to the PROcede. IMO makes sence with FMIC, DP's or both mods. BTW, congratulations to V2 ! Thank you for feedback. Cheers Eugen |
10-12-2007, 04:17 PM | #2 | |
44
Rep 428
10-12-2007, 06:27 PM | #4 |
35
Rep 1,169
Drives: 67 GT500,69 Boss 429, 335i
/me suspects its already there... just wire it up and test
-Mat
Tuned E92 335, Riss Racing downpipes! And hopefully over 400RWHP!! |
10-13-2007, 10:10 AM | #6 |
Moderator
618
Rep 10,855
Spill the beans. And let us know what the E93 is like at 170 / 280 Eugen.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
10-13-2007, 11:24 AM | #7 |
Moderator
270
Rep 4,481
PROcede V2, the 335i's speed limiter and me
Hi !
Now, nothing progresses until you do it and so I started my speed limiter journey today. First I had a look at the V2.0.1 map to find any strings indicating that the PROcede uses code to deal with the road speed. I found such strings. In Schneid's weapon thread you see a cross reference where to find the speed signal for this function. The RDsport blackbox uses this wire. I rechecked with the BMW WDS, and it looked good to me. It is the white/green wire pin #17 on the grey subconnector of the smaller ECU connector. I intercepted it using my spare loom, the old green loom which will be replaced when you upgrade to V2. Thus defending the speed limiter needs a digital I/O there is not much choice. Digital I/O number 4 is the only available digital channel. - I extracted the white/green wire of pin #17 of the grey subconnector of the smaller ECU connector and connected it to pin #4 ( digital input #4 ) of the black PROcede connector. - I connected pin #9 ( digital output #4 ) of the black PROcede connector to pin #17 of the grey subconnector of the smaller ECU connector. Done. So far the car behaves normal, no side effects. Also no additional functionality in the PROcede Reader software. I have to test now if the speed limiter is really defended with this solution. I think I have a fair chance . If it works this will be applicable for PROcede V2 only !!! Cheers Eugen Last edited by e.n335; 10-13-2007 at 11:43 AM.. |
10-13-2007, 11:51 AM | #8 | |
137
Rep 6,608
10-13-2007, 11:57 AM | #9 |
Rep 210
Geez Eugen, you are a man of action. Full speed ahead and damn the torpedoes! I can't wait to hear about your test run. You are an inspiration to those of us who are to stupid or lack motivation to figure this crap out.
Drive safe
Fubarsky
10-13-2007, 12:20 PM | #10 |
113
Rep 750
10-13-2007, 12:26 PM | #11 | |
148
Rep 5,389
1. Sorry, but I'm a bit confused...does the PROcede already have this extra wire (pin #9 ( digital output #4 ) of the black PROcede connector) attached; I thought Shiv had mentioned that he forgot to send all of us initial V2 customers the extra wire??? 2. Let us know if your solution works! Thank you.
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | |
10-13-2007, 12:30 PM | #12 |
133
Rep 4,764
Excellent work, let us know your testing results soon! Be safe!
10-13-2007, 12:52 PM | #13 | |
Moderator
270
Rep 4,481
2. Sure - Eugen |
10-13-2007, 02:42 PM | #14 |
35
Rep 1,169
Eugen it works... its been tested . PM me if u need info.
-Mat
10-13-2007, 02:45 PM | #15 |
19
Rep 539
Drives: Car
Would we need the extra wire in the bypass plugs if we wanted to take out the procede and run with the plugs?
10-13-2007, 02:50 PM | #17 |
Moderator
270
Rep 4,481
10-13-2007, 02:51 PM | #18 |
Moderator
270
Rep 4,481
10-13-2007, 04:42 PM | #20 |
Moderator
618
Rep 10,855
Play it safe and take a trip to Germany for your speed run.
10-13-2007, 09:13 PM | #22 |
Moderator
618
Rep 10,855
This is why we work with straight talk here on E90post, letting everyone know what we know and don't know, and not playing cat&mouse.
